Page 2 of 21
Re: Newguys Sprint Conversion
Posted: Wed Feb 06, 2008 10:29 pm
by newguy
DavePoth wrote:The wooden bits will come off fairly quickly (4 screws to remove for the instrument panel bit and the hose for the vent) and the glovebox is just 6 screws for the panel and another 6 for the box, and the clock bit I can't remember but it isn't that hard at all.
Yea i have taken the Glove box and dial panels out before just not the whole dash i guess you figure it as you go etc.
Posted: Sat Feb 09, 2008 9:47 am
by newguy
Took the sprint motor and box and drive shaft out today.
think i dropped a washer down the dizzy hole into the motor i carn't find it.
Will update with a bit more info later or tomorrow....
Was a pretty productive day, for got to take the prop shaft out of the sprint shell though.
Few Pics
Oh dear......
Posted: Sat Feb 09, 2008 1:20 pm
by sprint95m
newguy wrote:Took the sprint motor and box and drive shaft out today.
This is potentially bad news. If it was me, I would want to fish it out. Try moving the engine to a different angle to see if the washer moves into view?
If not, there is a core plug beside where the distributor sits (its one of two core plugs between distributor and water pump). If you remove it you may then be able to locate the lost washer.
I'm afraid you may be looking at having to remove the jackshaft.
Apart from this hiccup, good pictures and progress though.
Posted: Sat Feb 09, 2008 10:11 pm
by newguy
Hmmm s##t, how do you take that shaft out etc?
Time consuming...............
Posted: Sat Feb 09, 2008 11:10 pm
by sprint95m
Undo crankshaft pulley nut (but don't remove it yet).
Remove inlet manifold (c/w carbs).
Remove water pump cover and then pump itself.
Remove fuel pump.
Remove rocker cover.
Undo camshaft sprocket (ensuring before you do this that the camshaft is lined up on the marks, if necessary turn the crankshaft pulley to achieve this) and attach sprocket to the support bracket.
Remove crankshaft bolt and pulley.
Remove timing cover ( it should not be necessary to slacken the sump).
Remove timing chain tensioner and slacken bolts on curved chain guide ( I am not sure if you need to remove this guide but suppose you may as well).
Remove support bracket bolts and then remove bracket c/w chain (with camshaft sprocket still attached).
Remove bolt and sprocket from jackshaft.
Remove jackshaft securing plate followed by the jackshaft itself (it should just pull out).
(I think it should be OK to leave the straight guide in place. When I replaced the chain on the Sprint, I fitted new guides and tensioner.)
Stew, I suggest you persevere trying to locate the lost washer before resorting to jackshaft removal as it is a lot of work.
If you wait a few days, maybe a forum user will have a suggestion for locating said washer without all this dismantling. (Is the washer hidden by the distributor drive gear on the jackshaft?)
Good luck.
Posted: Sun Feb 10, 2008 12:11 am
by straylight
keep up the good work stew, great to see this happening across the ditch.
also great to see the odds and ends people have lying around their sheds
nice looking kart !
Re: Time consuming...............
Posted: Sun Feb 10, 2008 12:21 am
by newguy
Good luck.
That does look like alot of work, i am not 100% sure that it went down there, i just thought i saw something like a washer fall down there.
I can not see anything in direct sight.
I have removed the Manifold and carbs, Rocker Cover, water pump, fuel pump,distro of course lol, spark plugs so shes easy to turn over. So i can spin the engine with the torque converter an i can not hear or see is.
It may have gone down into the oil pump as i can see its shaft looking straight at me.( from down the distro hole.
How far back from where the shaft is could the washer go back towards the head? Under neath it etc?
Will take the head, timing cover off this weekend, as i am going to have the head crack tested and the same to the block thats done less than 2000miles!!!!
Thinking i might get the whole engine balanced also.
Could the washer find its way down into the sump?
Posted: Sun Feb 10, 2008 12:23 am
by newguy
straylight wrote:keep up the good work stew, great to see this happening across the ditch.
nice looking kart !
Cheers Stu, gunna try and beat you Haha
Love the kart used to be mine but my dads sort of taken is over they drive it round at 3am after a few bottles of rums, good times
Also im only 19 guys so this is a big effort for me i think.
Should get the rust all patched up next we im thinking.
Posted: Sun Feb 10, 2008 1:25 am
by straylight
maybe fish around for the washer with a magnetic pick up tool, you know the ones ?
3.00am kart driving.....sounds dangerous......
I've resisted the urge to jump onto a kart, but the will power is waning. There is a local dirt Kart club in town.
must resist, too much else to do
Looking at the orange shell, it looks like you have a nice pair of vehicles there to work with. You got your first(?) engine out at 19, I only achieved that feat at 45 ! I had a few excuses and did just about everything else though. Well done mate, well done.
you could do with a sprint 4sp gearbox and OD yeah ? dunno if there is a solution to getting the one from my donor across the Tasman, I think I'm going to leave it in the donor anyway and restore the donor eventually, but if you are going to these lengths, snagging a spint box would be awesome.
Posted: Sun Feb 10, 2008 2:21 am
by newguy
straylight wrote:maybe fish around for the washer with a magnetic pick up tool, you know the ones ?
Yup 3am Kart Driving is hell dangerous but it is alot of fun trust me, kart handles great.
Slicks on the back with treads on the front.
just re powered her with a new 6.5HP with a excellent American clutch.
This is the 2nd time ive pulled out the engines on this car first time was 2 years ago when i did a full rebuild from a destroyed cylinder. So my first pull out was 17, but my farther lent me a hand. Done these two all on my own.
I have a 4Sp Box With OD, from a sprint, although i am looking for Drive shaft, because i do need to get one of mine shortened or lengthened which could cost.
It has to be done right over here.
Thanks for the offer though
My 4Spd with OD
Posted: Sun Feb 10, 2008 6:49 am
by newguy
Well i didnt have alot of time to get much done on the car today but a fellow sprinter came round to check out what i was doing and gave me the contacts of where he brought the clutch equipment for his car.
Feels nice as.
So thats what ill be getting.
I also found the other bits i needed for the clutch.
So now i just got sort the driveshaft
Posted: Tue Feb 12, 2008 8:14 am
by newguy
Pulled the bottom of thedash out in the 1850 sheel tonight to get the trans tunnel out and look for any rust.
Ended up pulling the Clutch cylinder off as it had seized up.
Will post some pictures tomorrow, also gunna go pick my new clutch up.
Epic
Posted: Wed Feb 13, 2008 3:30 am
by newguy
Posted: Wed Feb 13, 2008 3:37 am
by newguy
Posted: Thu Feb 14, 2008 3:49 am
by newguy
Alright well this might get up your guys noses.
But i just went and got my Clutch Master and Slave Cylinder
And i paid $37.75 NZ So thats ummm 15 Pounds For Both.
So im a happy boy, though i have to get a new Hose made.
Going to sort that tomorrow, Braid SS i guess as you guys have advised?
Pics of the items.
I hope this made your day
Atleast one of us is getting a great deal.
