Page 2 of 2
Re: Cam Timing
Posted: Tue Mar 25, 2008 12:18 am
by Mad Mart
If you don't align the Jackshaft correctly then you won't get the dizzy adjuster bolts near the centre of the slot, it will be towards one end or the other. Lift the dizzy out & turn it one tooth & it will be at the other end. You need to set it up correctly to give you maximum adjustment both ways.
Re: Cam Timing
Posted: Tue Mar 25, 2008 10:56 am
by newguy
Got it all done, jack shaft lined up cam lined up top dead centre on the crank etc.
Now i just got to decide which method of which to torque the head down to.
Cheers for you inputs
Re: Cam Timing
Posted: Tue Mar 25, 2008 1:44 pm
by Mad Mart
Just use the sequence in the Haynes manual, but use 58 ft lbs (78 Nm) as the last torque figure.
Re: Cam Timing
Posted: Tue Mar 25, 2008 7:29 pm
by newguy
Are you sure?
Do you use this method?
Re: Cam Timing
Posted: Tue Mar 25, 2008 9:56 pm
by Mad Mart
Yep, have done for years.
Re: Cam Timing
Posted: Mon Mar 31, 2008 10:44 pm
by Inca-Sprint
Im at this stage too.
Is it the done thing to have the curved guide tight up against chain removing as much slack as poss? ( ie chain running straight off of jackshaft and straight up against guide?)
And then finally relaeasing tensioner?
Hope you get what i mean!?
Re: Cam Timing
Posted: Tue Apr 01, 2008 12:21 am
by Mad Mart
Yes, once you've got the cam & crankshaft where you want them (or should I say, where they should be), push the curved guide against the chain & tighten the 4 bolts up. Then you can release the tensioner. Don't forget to remove the bottom one of the 4 bolts other wise the timing cover won't go on.
Re: Cam Timing
Posted: Tue Apr 01, 2008 12:28 am
by Sprint36
As Mart says, except that I don't make the chain too tight with the curved guide so that you can tell if the tensioner has popped out. I had a non-tensioning tensioner last year that lunched itself and the chain because it never sprung out when pushed in.
David
Re: Cam Timing
Posted: Tue Apr 01, 2008 9:30 am
by newguy
So you want the tensioner as tight as you can get it but so its not in the first slot?
