i was gona offer you a front inner panel, but looks like you have the bits to sort it...
watching with interest...
Just what I had planned in the absence of OE stuffMalcGE wrote:You may find yout headlamp mount panels can easily be repaired, I used the inner half and made up new outer half.
Again, will fabricate as close as possible to original. I found another wing with half the eyebrow and light panel where it had been sliced off so can drill the welds out and use these as templates.MalcGE wrote:Eybrow panels, same agin, the top section was good, just a bit down the sides.
