Page 2 of 3
Re: Oil pressure
Posted: Sun Apr 05, 2009 11:11 pm
by xvivalve
Must be easier with a ramp, couldn't get the ends of the split pin straightened today as unable to get decent access through the subframe and around the rack whilst lying on my back. I'll go beg a favour with a commercial place with a ramp in the week...
Re: Oil pressure
Posted: Mon Apr 06, 2009 11:00 am
by Jod Clark
Or bring it to mine, and I'll do it from down t'pit
Re: Oil pressure
Posted: Mon Apr 06, 2009 12:02 pm
by triple tango
I did it lying on the floor ok.
Re: Oil pressure
Posted: Wed Apr 08, 2009 11:56 am
by xvivalve
Roy, did you take the pump off or did you get the split pin out in situ?
Re: Oil pressure
Posted: Wed Apr 08, 2009 1:39 pm
by triple tango
I didnt disturb pump, split pin removed in situ ok.
Re: Oil pressure
Posted: Tue Apr 14, 2009 8:38 pm
by Jod Clark
Think it'll need doing sooner rather than later - started her up today whilst she is sitting at my place awaiting propshaft repair and she blew the rubber seal out from the oil filter. Only three hours tidying up to do then
. Sprinty pump sure do shift some oil, even at tickover.
Re: Oil pressure
Posted: Thu Apr 16, 2009 9:28 am
by xvivalve
Hope you didn't run my bearings whilst using my very expensive engine as a musical instrument!
Re: Oil pressure
Posted: Sun Apr 19, 2009 10:58 pm
by newguy
Jod Clark wrote:Think it'll need doing sooner rather than later - started her up today whilst she is sitting at my place awaiting propshaft repair and she blew the rubber seal out from the oil filter. Only three hours tidying up to do then
Are you using a spin on?
Re: Oil pressure
Posted: Mon Apr 20, 2009 1:39 pm
by xvivalve
Yes, may revert to standard as at least then the seal is trapped!
Re: Oil pressure
Posted: Wed Apr 22, 2009 11:12 am
by newguy
Guessing your having the same problem as me, you have the Wrong filter fitted.
Re: Oil pressure
Posted: Thu Apr 23, 2009 10:04 am
by xvivalve
Really?
So what is the correct filter for the spin on conversion? I simply replaced like for like with what was on when I bought the car...
Re: Oil pressure
Posted: Mon Apr 27, 2009 5:38 am
by newguy
xvivalve wrote:Really?
I did the Same
But it was wrng the seal seals but only just it just just touches its so close.
I will post the right number tomorrow mate, i had two filters the same that blew and blew, now i have the right filter i have no problems.
Actually ill post it tonight when i get home.
Cheers Stew
Re: Oil pressure
Posted: Mon Apr 27, 2009 5:40 am
by newguy
Here is my Thread From my Local Forum about it
http://www.oldschool.co.nz/phpbb/viewto ... hilit=+Oil
Hava Read it onli 1 Page
Re: Oil pressure
Posted: Mon Apr 27, 2009 5:42 am
by newguy
Now that i think about it that exercise cost me over $200 easy, s##t!
Re: Oil pressure
Posted: Tue Apr 28, 2009 9:10 pm
by newguy
Do you still need me to get the right number?
What i thought was my spare is now under the car.
I don't mind just haven't had a reply from you.
Cheers Stew
