Will do, going for MOT on Sat then new exhaust manifold to replace my crap effort in a couple of weeks.ToledoZombie wrote:Great stuff, now lets see a video of it in action . .
Ian
I haven't replace the member but this should be straightforward to either weld in either a tube section to link the hole or use box section and the original sprint subframe mount holes. Taking the car for a quick run or private roads of coursesprint95m wrote:Been watching your progress with great interest and am pleased you are now mobile.
Now you have reached this point, I have a couple of questions to ask, if I may.
Did you do anything about replacing the member from the front subframe you removed?iandollysprint wrote: Front subframe - I think eightiesflamer(?) redtop conversion does not use any replacement. I think it would be relatively straight forward to use the original sprint mounting holes and fabricate with box section a replacement for the bit I have chopped out. I will probably do this.
If not, how does the car drive?
How is the gearbox mount?
It looks to me like you used a Dolomite o/d one?
A Sierra mount is very similar but a bit bigger. I have adapted a Dolomite o/d crossmember to accept one and am hopeful it
will be an improvement.
It's £700 for the manifold, not the complete exhaustToledo Man wrote:£700 seems a bit steep even for a custom made exhaust. Get some more quotes if you haven't already. Can't anyone else recommend somebody who doesn't charge the Earth?
mbellinger wrote:Congratulations Ian - just reward for all the hard work.
Wait until you do rev it out - it will stand your hair on end I can assure you.
You are correct that the exhaust manifold is pivotal with these engines (and also can make them sound like a Ferrari!!).
Delighted you have got the car on the road at last.
