Page 12 of 15
Re: VA138, the next chapter....
Posted: Fri Jan 13, 2023 7:14 pm
by shaunroche
RSi wrote: ↑Fri Jan 13, 2023 2:29 pm
...is that the chap who worked for Aldridge?
The very same yeah, Cliff, nothing but the best for this job!
Posted: Mon Jan 16, 2023 12:51 pm
by RSi
shaunroche wrote: ↑Fri Jan 13, 2023 7:14 pm
Top job!
Posted: Fri Jan 20, 2023 9:40 pm
by shaunroche
Feel like we've turned a corner today...
Posted: Fri Jan 20, 2023 11:45 pm
by Tony Burd
Looking good Shaun.
What did Cliff do at the gutters with the vinyl, does it overlap slightly so the chrome gutter trim fits over it?
Posted: Sat Jan 21, 2023 9:52 am
by RSi
shaunroche wrote: ↑Fri Jan 20, 2023 9:40 pm
Looks excellent.
What did he use for the pillars.
Posted: Sat Jan 21, 2023 5:10 pm
by shaunroche
Posted: Mon Jan 23, 2023 9:04 am
by RSi
Great post to follow. Really nice to see the car coming together.
Posted: Mon Jan 23, 2023 1:46 pm
You are more than welcome! BTW the lower A post cards are trimmed with carpet, as per what has been done, but only on series 1 cars, (up to VA 15000), later models have black vinyl here!
Posted: Mon Jan 23, 2023 3:23 pm
by RSi
Carledo wrote: ↑Mon Jan 23, 2023 1:46 pm
I did wonder - and I think the carpet looks way better.
Posted: Fri Feb 03, 2023 9:50 am
by shaunroche
Tony Burd wrote: ↑Fri Jan 20, 2023 11:45 pm
Looking good Shaun.
Hi Tony - sorry, only just spotted this post!
I'll go over and have a look later but it looks like he's got it going up to the gutter rail rather than over it which is good!
**Edited**
Posted: Fri Feb 03, 2023 9:59 am
by shaunroche
The car's going back to the Sprayer's soon for a bit of remedial work and whilst it's there I'll start installing the concentric clutch mechanism up - no way should any sprint have that God-awful slave cylinder/cross shaft rubbish set up. I have one of these fitted to my Track car and it hasn't given me a second's bother so this was a no brainer.
Once sorted it'll be nailed to the engine, the engine dressed and when the car's back from the sprayers, all assembled in.
Posted: Tue Feb 07, 2023 9:39 pm
by shaunroche
Posted: Wed Feb 08, 2023 12:38 am
The Vinyl is only meant to go up to just below the top edge of the gutter. There SHOULD be around 8-10 clips (whole car) in 2 different specs that kinda keep the vinyl tight while you fit the gutter mouldings. These seldom survive the first respray and are NLA so you don't often see them.
If you have the vinyl lapped OVER the top of the gutter so it's under the trim, well in my experience, you don't! The trim won't go on, hard enough to get them on without damage when it's done right.Cliff does a "proper job"!
Posted: Sat Feb 11, 2023 10:49 pm
by shaunroche
Posted: Sat Feb 11, 2023 11:06 pm
by shaunroche
shaunroche wrote: ↑Sun Sep 02, 2018 10:59 pm
oily66 wrote: ↑Sun Sep 02, 2018 9:29 pm
....Good luck with the build Shaun. On your past build this should be cracking, looking forward to it.
Thanks for your kind words Trevor!
I don't plan on spending as much on it as I did on my white Sprint, but it will be done properly....
Hmmm....don't know if I was being optimistic or really naïve, but the budget went out of the window years ago! 🫣
