Page 16 of 18
Re: Project PUS (Sapphire Sprint)
Posted: Wed Sep 28, 2011 8:45 pm
by Mad Mart
Well it
was the waterpump. The splines had completely gone on the top of the shaft so the impeller was slipping a bit. Obviously the more revs the more it slipped & the louder the squeal. It's great to have found the fault but I don't know why it has done this.
Posted: Wed Sep 28, 2011 9:40 pm
by 80Sprint
I managed to smash mine whilst pulling it all apart. I could only get a replacement from Jonners at the time which was prone to spinning as well so i drilled the impellor both sides and tapped in grub screws and dimpled the shaft. Added some locktite and all seems well so far ......
Posted: Thu Sep 29, 2011 8:27 pm
by Jon Tilson
The Alun fix is to drill a hole between impellor and shaft parallel to the axis of the shaft and drift in a roll pin....
A very nifty solution. It doesnt need much...just enough to stop it spinning.
Posted: Thu Sep 29, 2011 8:34 pm
by Mad Mart
Now that's a handy tip(s) as I have a 12 vane impellor that has been machined but the splines are gone.
Posted: Thu Sep 29, 2011 9:49 pm
by SPRINTPARTS
Scotch Dowel. Works a treat. If you are a real tight a*** or don't have a roll pin available a small diameter nail or even the inner shaft from a pop rivet will also work.
Posted: Sat Oct 08, 2011 11:26 am
by Mad Mart
I finally took PUS back to the spray shop this morning. I'm always apprehensive taking my projects on the road for the first time.
But I am glad to report that the maiden drive was great, apart from the fuel & temp. gauge not working for the first mile or so, then they started working (probably a bad connection on the VS) and the throttle is sticking slightly. So it will be in for an MoT test on Monday and then the sprayer will be finishing off, hopefully have it back by next weekend.
Posted: Mon Oct 10, 2011 6:57 pm
by Mad Mart
PUS has an MoT.
Three advisories:- 1. Exhaust blowing on joint. Obviously I knew about that & told them about it. I need to get a meatier clamp as the standard cheapy ones don't seem to be man enough. Can't remember the size off hand, anyone advise? 2. Play in front wheel bearing. I guess the bearings settled a little on the journey down. 3. Sprayer couldn't remember so I'll let you know later in the week.
Posted: Tue Oct 11, 2011 12:37 am
by straylight
well done Mart, another sprint back to life and the legacy lives on. Thanks.
stu
Posted: Wed Oct 12, 2011 1:00 am
by xvivalve
Next...!
When are you coming shopping?
Posted: Wed Oct 12, 2011 7:54 am
by Mad Mart
xvivalve wrote:Next...!
I almost came up the other week. I shall be up shortly to view a couple of the vehicles you sent me photos of & probably bring a couple of old core starter motors with me.
Posted: Wed Oct 12, 2011 8:16 am
by Toledo Man
Are you going to do the blue Auto next?
Posted: Wed Oct 12, 2011 4:39 pm
by Toledo Man
Alun has one. When I was down there I joked that it should be Mart's next project as he hasn't done an auto yet.
Posted: Wed Oct 12, 2011 4:46 pm
by Mad Mart
No, I won't be restoring that one. I believe the blue auto is Alun's next resto?
Posted: Wed Oct 12, 2011 11:04 pm
by Toledo Man
The carmine Sprint with the Zintec sills that haven't rusted since they were fitted?
Posted: Sat Oct 22, 2011 5:18 pm
by Mad Mart
