The issue with the bush has been resolved. It looked like the column wasnt in quite far enough. Now once the internediate UJ is on with the washer it no longer rotates with the column.
You might remember that I wasn't happy with the condition of the track rods, they were quite pitted and were no where near my standards so I redid them.
They look much better now.... until someone uses a pipe wrench to adjust the tracking, which won't be happening I assure you!!
I did some more finishing on the rack body as well to remove as much of the visible pitting as I could.
I dont think I showed any detail of the new rack bush that I fitted.
So, onwards. Using the new polybush cups I rebuilt the tie rod ball joints setting them up to be about the same tension as a track rod end. I'm actually very happy with the way they are now, the new cups have made a huge difference. The nuts are torqued up to 80 lbf-ft with a big socket and a vice, then I bent the lock tabs over.
I then mounted the right hand one on the shaft with the spring and locking nut. This time when I pot the tie rod assembly on I was able to wind it into the shaft properly and lock it off as per the manual which leads me to believe that the old cups may have simply had it. Again, everything been torqued up to 80 lbf-ft using a big crows foot spanner.
I then thoroughly greased up the bush and shaft and slid it in the body, and using a vice to support the opposite end I did the same and installed the left hand tie rod assembly. This time you'll need to use a spanner to prevent twisting the shaft and damaging it.
I haven't received my replacement pinion for Jigsaw, it's going to be a few weeks so I have put the original one back in for the time being.
The new bearing has been packed with grease and slid onto the pinion, to do this I put the pinion in the freezer with the peas for a few hours. Everything is held together with a circlip. I also replaced the seal in the pinion end plug.
I then put a new grease nipple on the base of the housing and made sure that there was plenty of grease in the lower bush before installing the pinion in the rack, then I used the pinion eng plug to press the ball race down into its seat.
I then greased up the rack damper and installed it with the spring and tightened it down just enough to remove and play for the rack. As I will be replacing the pinion I won't bother shimming it up as this will change with the size of the new pinion.
Before installing the nylon plug on the left hand side of the rack body I used the grease gun to get a bit more grease down that end of the rack, the plug was then just held in place with a length of insulation tape.
Just need to finish cleaning and fit the gaiters and it can be fitted back into the car.
