Im happy with it now so can move on to other things.
What was your reason for getting the Timken ones, curious - as I'm putting new bearings on too.Bish wrote: ↑Sun Jan 16, 2022 11:10 pm The front wheel bearings needed replacing. A nice little job on a Sunday morning. Not interesting to read about really. But I wanted to point out that if you are in need of bearings, don’t buy from Grimmers etc. Get them from https://www.bearing-king.co.uk/ or a similar supplier. Proper quality bearings at a decent price. I chose Timken, but you could have SKF or similar if you prefer. Much better than the eBay rubbish and cheap enough too.
Inner bearing is LM11949 outer is L44649. Obviously that’s Timken codes but if you pop that into the search on the bearing king website you will get the other brands they offer in the sizes you require.
The four bearings supplied and delivered next day for £57.
Much better quality Murdo, there is so much rubbish out there. Timken are a fit and forget for a good while at leastRSi wrote: ↑Tue Feb 08, 2022 11:58 amWhat was you reason for getting the Timken ones, curious - as I'm putting new bearings in too.Bish wrote: ↑Sun Jan 16, 2022 11:10 pm The front wheel bearings needed replacing. A nice little job on a Sunday morning. Not interesting to read about really. But I wanted to point out that if you are in need of bearings, don’t buy from Grimmers etc. Get them from https://www.bearing-king.co.uk/ or a similar supplier. Proper quality bearings at a decent price. I chose Timken, but you could have SKF or similar if you prefer. Much better than the eBay rubbish and cheap enough too.
I wonder are the bearings the same for all Sprint, no difference depending on year of model.
Thanks Tony, that's greatdollyman wrote: ↑Wed Feb 09, 2022 11:09 amMuch better quality Murdo, there is so much rubbish out there. Timken are a fit and forget for a good while at leastRSi wrote: ↑Tue Feb 08, 2022 11:58 amWhat was you reason for getting the Timken ones, curious - as I'm putting new bearings in too.Bish wrote: ↑Sun Jan 16, 2022 11:10 pm The front wheel bearings needed replacing. A nice little job on a Sunday morning. Not interesting to read about really. But I wanted to point out that if you are in need of bearings, don’t buy from Grimmers etc. Get them from https://www.bearing-king.co.uk/ or a similar supplier. Proper quality bearings at a decent price. I chose Timken, but you could have SKF or similar if you prefer. Much better than the eBay rubbish and cheap enough too.
I wonder are the bearings the same for all Sprint, no difference depending on year of model.![]()
