Thanks for the note. This is well worth exploring given the lack of a conclusive root cause to the original failure!soe8m wrote:Maybe with some factor X petrol in the oil the lubrication quality decreases more than the viscosity so maybe even before an oilpressure loss is noticable the lubrication is very bad.
I have no experience with bike carbs on a car but how is the fuel supply? Is it on the original bike just a line from the tank and now you have a petrol pump? If this is the case your floatneedles are not designed for a pump pressure and the mixture is while driving way too rich by little flooding.
The bike carb set up is as follows
Original feed from tank remains into constant pressure pump delivering 3 psi fuel pressure to rail and bowls. This pump is from the bike set up so should be fine.
Carbs have had the main jets drilled to 1.8mm from 1.6mm I think. This is following various recommedations on other furms when using a C20xe engine on r1 bike carbs. It's the "thing" to do and is backed up by Bogg Brothers who also set bike carbs up as well as making and selling bespoke inlet manifolds to suit.
So I should be in the right "ball park" here. My engine spec is slightly different than standard as it has 276 degree high lift cams.
I have previously done a lambda check on my M635CSI where we shoved a lambda probe up the exhaust and took it for a full load run in 3rd gear to the redline.
So I think I should repeat this on the XE sprint which will at least tell me if things are a miss. Should be able to determine idle conditions as well. I think it was about £30 to do last time.
Obviously a full set up is needed at some point but I would only do this after the engine has been run in allowing me to run the full rpm range AND after the exhaust manifold has been sorted. I might be able to do this test end of this week which will take me forward.
I'll post results.
Ian
