My Sprint does this after a coolant flush and refill, following the handbook method of not getting air trapped is awkward, Jonners method of taking off the filler bung and squeezingJames467 wrote: ↑Sat Jun 30, 2018 10:55 am Temps are running a bit high for my liking. I want to sort this now before tuning as that will make it worse.
Just been to Tunbridge Wells and back via the M25. Roughly a 150 mile round trip. When I left it was not hot, probably about 15 degrees, quite pleasant.
On normal driving the needle is about here, the electric fan kicks in and out happily. I'll add quickly that I did not take the photos
On the Motorway it is up here at an indicated 75-80, if I turn the fan off it will get hotter.
On the motorway I had to have the heater on full hot and the fan going to get the temp down to a reasonable level.
The car happily sits at motorway speeds, it climbed Reigate hill on the M25 with relative ease. It did get hot again, but cooled down the other side.
The radiator is new and a Sprint one at that. Cooling system is all in good health with no leaks now and a new water pump. Voltage regulator is new and the temp sender is Robsport.
Is there a way that I can test the gauge? Tony, you'd probably know this! I'm wondering if I do have a heat problem at all and the sensor and voltage regulator are just fooling me and making the gauge read high.
The other thing I may do is fit an Aluminum Rad, one of those Alicool ones with the fan mounts.
the bottom driverside hose whilst the car is cold (and engine not running) always works for me.
Having said that, my thermostat seems to have developed a sticky spot and needs changing, only 9 months in the car and its failing, last problem I had was on the way to
Stoneleigh, the car was over cooling (as Martin put it), this turned out to be a dirty lead connection at the temp sender.
