Last week we had a water meter installed so the week before knowing this was due to be done I decided to clean the gearbox.
We went from this, as it was removed from the car on my newly constructed cradle...
30 years of oil and dirt
A reference for rewiring the overdrive...
After a good wash she scrubbed up well!
A little bit of damage here and there
Input shaft oil seal's still leaking then...
That's now stitting in the workshop waiting to be refurbished.
I also tidied up the workshop.
Then with nothing else to do I stripped down and cleaned the clutch master cylinder. It was new, relative to the car but I thought it would probably need new seals given the state of the brakes. this is what I found....
Not too bad and amazingly after a clean this is what the cylinder came up like
The inside has a small amount of surface rust but the bore was perfectly fine.
So with a new seal kit and a clean up it all went back together
Ran out of Castrol red grease so I couldn't do the slave cylinder, I'll post a pic when they're all done.
