Got a bit more done this afternoon.
First task was unload all the bits I got from John.
I had a rough plan in my head of what I wanted to get done. Ideally I wanted to get the new crank seal fitted and get the new clutch on and ready for the gearbox to go back on. I also wanted to get the steering rack/subframe cleaned up of oil and get the poly bushes fitted.
I started off by making up a tool to lock the flywheel. Ta daa!
Here it is in action.
That meant I could undo the flywheel bolts and whip it off. Here is what was underneath.
I took the gearbox adapter plate off, changed the seal and cleaned up the whole lot.
Adapter plate cleaned up and back on.
Then I cleaned up the flywheel and torqued it up.
Time for a cuppa and a browse through the book of lies ;D
I decided that I didn't want to risk contaminating the nice, clean, new clutch with my filthy hands, so I'll make that first job next time Im down the unit.
I turned my attention to the engine bay. As you can see, the steering rack is rather grubby where that crank oil seal was leaking.
I unbolted the rack mounts so I could change the bushes and clean around it. Heres the clean rack/subframe with the bushes in position.
And all bolted back together.
Thats it for today. Next time I'll get the clutch on. I need to put new seals in the Metro clutch cylinder before that though, because when I went to leave I couldn't get any gears! >:(
Edd
