Dolomite rear view mirror repairs
GrahamFountain
Re: Dolomite rear view mirror repairs
#31 Post by GrahamFountain »
new to this wrote: Mon Apr 06, 2020 6:10 pm Cant get to my car at the moment,but where do they brake is it the mirror end or where the mirror attaches to the body work
mines broke from the body work end,i see Paddocks sell a bracket for the Stag mirror are they the same for Dolomite
Most seem to have split the mounting where the stalk attaches to the body. But I did break the dip lever on a mirror once.
The Stag one has a stalk that is too short. I fit one to the headrail and mounted the mirror on it, but the mirror was too high up - if I set it to see out of the back window, I couldn't see very far; if I tried to see further back, the back edge of the roof was in the way. So it will work, but only if you sit lower down or further back than I find comfy.
new to this
#32 Post by new to this »
GrahamFountain wrote: Thu Apr 09, 2020 6:32 pm
Thanks, what i meant was will a dolomite mirror stalk fit in a Stag body mount
GrahamFountain
#33 Post by GrahamFountain »
new to this wrote: Thu Apr 09, 2020 7:29 pm Thanks, what i meant was will a dolomite mirror stalk fit in a Stag body mount
I couldn't see how, even by grinding the bulb off the end of the Doly's stalk. I even looked into soldering/welding the zinc/aluminium alloy they're made of to make one of two, but it looks too much like hard work to me.
new to this
#34 Post by new to this »
GrahamFountain wrote: Fri Apr 17, 2020 6:11 pm
ive now seen a photo of what the dolomite mirror mounts looks like and yes there completely different,
Oh.....
#35 Post by sprint95m »
GrahamFountain wrote: Thu Apr 09, 2020 6:32 pmThe Stag one has a stalk that is too short.
Could you not have a mounting boss of a suitable depth to lower the mirror?
A cheaper alternative to a Stag mirror is https://www.carbuilder.com/uk/long-stal ... lack-225mm?
GrahamFountain
Re: Oh.....
#36 Post by GrahamFountain »
sprint95m wrote: Fri Apr 17, 2020 8:41 pm Could you not have a mounting boss of a suitable depth to lower the mirror?
The stag one's several inches shorter, and I don't think that much could be made up that way.
But the cheaper alternative looks to be only about one inch shorter than the Dolomite's, so, maybe, mounted on the old boss, it might be okay for all but the very tallest drivers. Certainly looks worth a try at that price if the Italian job doesn't come good, or till it does if it's only waiting on a return to something like normality.
fenboy
#37 Post by fenboy »
I just had to make the repair to my mirror mount. It was broken in two and had been repaired using hot glue (I think) by the previous owner. Took a while to get all the old glue off!
I did the Araldite and screws repair but first added a cable tie around the top of the mount. I got it good and tight and it was good enough to allow me to plug in the stalk afterwards. I added the screws and Araldite after that.
The mount needed a bit of fettling with my Dremel to stop the cable tie from popping off - just made the corners straight and parallel.
You can barely see the cable tie and it seems ok so far!
David
