sprint95m wrote:
Oh, but you can. Standard service items for a xantia aren't expensive. Suspension sphers £25 a corner (bit naughty, should have replaced all four, but did front and back seperately). Brake pads and even discs can be got for less than £50. Cam belt and auxillary drive belt all less than £50. Even a kit to replace a suspension baring at the back was uner £40.
So how do you get the big ticket items cheap? Scrap yards and luck. We needed a new door, trip to the scrap yard, right colour, £40. Replacement brake calipar, strip it off a crap car, £20. Even managed to get a new suspension pump for £25 (it had the worng pulley, but easy to switch).
The only big bill I've had in the last 4 years was for a hydralic regulator, £125. Your right, if I did all the jobs in one go, then it would be more, but I tend to do things little and often. Still if your car is common enough, you do the work yourself, use scrap parts and shop arround. You can do things surprisingly cheap.
That is a weak answer. It is hardly a "high standard"? By the way, that is actually £450 in parts, seeing as
(25x4)+50+50+40+40+20+25+125=450.
You can buy things like ARB drop links for a fraction of the Citroen price, but given that you'll be replacing the cheap replacement in
a short time, which is cost effective?
They Citroens (& French cars in general) are a nightmare to try and get the correct parts for, even using the chassis number,
because there are so many options.
I maintain one for a friend who says he'll run it 'til it dies. It needed very little for the last MOT but was still way over £50 in parts.
Their only good point is the incredible low prices I suppose, eg £150 with a full MOT (which in itself is £54).
Ian.[/quote]
Well yes I said I never spent more than £50 on parts, I didn't say over a year. To be fair all that work wasn't done this year. Generally it requires a new trackrod end, bulbs, horn, pads to pass the MOT, nothing too difficult. Occassional big job, failed suspension bearing, suspension pump blew up (fun job that one, you can't actually get a jack under a mark one Xantia when the hydraulics are broken).
Oh I wouldn't run one as a banger given the choice, they are complicated beasts, but I got it free.
As for dealers, never buy parts from them, I don't believe that they are higher quality, and prices they charge are a nightmare. Simple service items shop around, expensive bits down the scrap yard. Not exactly a dream car, but it is comfortable, it will do 45mpg and the engine is virtually indestructable (provided the head gasket doesn't go). It is a b****r to work though.
