Page 3 of 5
Re: windscreen rubbers - finishers and trim clips - how much
Posted: Thu Aug 01, 2013 10:21 pm
by Edin Dundee
Hi Ian,
I will be getting the train back to Edinburgh tomorrow - don't ask! and will have lots of room in the lock-up to measure the rear glasses I have over the weekend.
Posted: Fri Aug 02, 2013 9:00 am
by DoloWIGHTY
I too should be able to get up into the roof space of my garage this weekend and measure the spare one that is up there.
Posted: Fri Aug 02, 2013 10:41 am
by Jon Tilson
Those of you wanting a rubber for the early zebrazone toughened screen either tinted or not will be ok with the Baines rubber.
Go direct and ask for the Toledo/1500 one.
It will seal ok but wont last forever...it soon splits at the corners, but you can fill it in with dum dum....or your black runbbery sealant of choice.
I've had one on mine for about 5 years now....it doesnt leak.
It WILL leak if used with a laminated screen....
Okay.........
Posted: Fri Aug 02, 2013 4:10 pm
by sprint95m
I am led to believe a T2000 saloon's back windscreen has a perimeter some 10cm longer than a Dolomite.
Chris Witor has had these remade to his high standards in EDPM rubber......
http://www.chriswitor.com/proddetail.php?prod=625141RM
http://www.chriswitor.com/proddetail.php?prod=913938RM
and
http://www.chriswitor.com/proddetail.php?prod=807398RM
That only leaves the front rubber to source.
I have a used example of the toughened screen's rubber but that doesn't help much because the priority has to be a the laminated screen type.
Anyone got one of these.........?
Posted: Fri Aug 02, 2013 9:46 pm
by Jon Tilson
So being thick I take it that means you have to cut the rubber and join it again having trimmed 10cm out.
Where do you recommend doing the cut? Should be OK cos the non OE rubber on Z magnettes is done the same way....you have to join it with suitable
adhesive.
Re: Okay.........
Posted: Sat Aug 03, 2013 12:16 pm
by DoloWIGHTY
I have this one:
As removed from my '75 1850.
If you would like it Ian for the purposes of remanufacturer then let me know and we can sort out getting it to you.
Posted: Sat Aug 03, 2013 1:02 pm
by SprintMWU773V
As I mentioned enquires are in progress so we may be able to secure some fronts but we would need to order at least 100. I cant see a smaller quantity being viable particularly if a new supplier needs tooling. If anyone would like to discuss or coordinate then perhaps get in touch else this will just end up with several if us trying to do the same thing.
Posted: Sat Aug 03, 2013 6:05 pm
Mark, If you (or someone) can organise a run of 100 units that will come out at a sensible price then I will fund it and do the stocking and distribution, any and all profits to club funds naturally!
Posted: Sat Aug 03, 2013 6:13 pm
Jon Tilson wrote:So being thick I take it that means you have to cut the rubber and join it again having trimmed 10cm out.
adhesive.
Traditionally the cut is at the bottom centre, all rubbers are made this way, its just hard to find the join in an OE one! I recommend a cyanoacrylate adhesive for the join (I've had to reglue some OE ones in the past, particularly the rear side windows on my Volvo 122S Estate, one of the few bits for these which is NLA)
Posted: Sat Aug 03, 2013 7:40 pm
by xvivalve
I thought it was OE, but I appear to have used that one, but I do have an old aftermarket '904111' still in its bag. Made by cti or tti or cci, can't quite decipher the logo
Posted: Sun Aug 04, 2013 7:59 pm
by Edin Dundee
I have a (damaged) laminated front sundym screen with rubber and trim.
I have no idea of the provenance of this screen and rubber and trim - it was donated to me by Jod a few years ago
There is a join in the rubber at the centre top.
The plastic trim insert is different to the rear trim inserts.
I have samples of both, but as I said I don't know where they came from (before Jod, that is). All of the measurements I take are the same for both trims, but they
are different, ever so subtle. The original one looks to be symetrical, the one from the laminated screen is not.
The screen is 5.3 mm thick.
I'll post photo's if I can.
IMG_2583 by
edindundee, on Flickr
The Join by
Details by
IMG_2584 by
Posted: Sun Aug 04, 2013 10:03 pm
by Toledo Man
Does anybody have the profile of the rubber? It is possible that Rarebits4Classics might have a suitable match in their extrusion catalogue which can be found
HERE. I know they're Herald specialist but there's an overlap with the Dolomite. I'm sure it might be worth investigating. Why look into getting the rubbers remanufactured if there's something suitable already out there?
Posted: Mon Aug 05, 2013 7:15 am
by rvfrc45
Hi All,
Just been looking at the windscreen rubber pictures and I can see the grove size is different from the baines rubber.
As I said before I have two new Baines rubbers that I will not use.
Can Edin Dundee please measure the depth of his old rubber grove and width with the glass out as I think
this is also important if we get them remade or find a suitable replacement.
The trouble is that if you buy a suitable replacement and still find it does not fit nice or leak you have not only wasted another £40
odd quid but time and poassible damaging the glass.
We must try get it right.
100% for all people trying to sort this.
Cheers GW
Posted: Mon Aug 05, 2013 9:29 am
by Edin Dundee
The screen rubbers are shot, so it's easy for me to cut off a section of each and compare - HOWEVER - as explained, i can't say if they are originals or aftermarkets..........
Posted: Mon Aug 05, 2013 10:27 am
by DoloWIGHTY
Looks to be like mine Bill - old, cracked and original.
If the club don't want mine then it's off tot he tip very shortly.
