How bad is my Sprint?
- SprintMWU773V
- TDC Staffs Area Organiser
Re: How bad is my Sprint?
For props see Dave Mac in Coventry. He'll either refurb yours or just make you a new one for the same money. Very pleased with my prop from there, turned round quick too.
- shaunroche
Cheers for this.....I've dropped them a line so we'll see how much they want!SprintMWU773V wrote:For props see Dave Mac in Coventry. He'll either refurb yours or just make you a new one for the same money. Very pleased with my prop from there, turned round quick too.
- SprintMWU773V
Wasn't that much actually, got them to paint it as well to make it look nice. In fact I've just popped some pics on my resto thread so you can see the before and after.
Hi Shaun,
Single line brake system on a track day Sprint? Are you sure thats a good idea?
Probably not but that's what I've had for the last 8-9 years.PaulB wrote:Hi Shaun,
- shaunroche
This would appear to be the least of my problems at the moment Paul...... Having a Piper 285 cam fitted to my head and it looks like the inlet lobes on 6 and 8 are misaligned.PaulB wrote:Hi Shaun,
Being advised not to fit it as it would cause premature wear of the rocker arms/cam lobes.....
- shaunroche
So...progressing a little now!
From this rusty tired old thing.....
To this powder coated affair all new bushes, stub axles, vertical links, bearings, ball joints and a Trackerjack brake conversion (better pics to follow)....
Some more goodies arrive....
Axle off and bits being made ready for powder coating before fitting new bushes....
Hmmm...
More to follow!
Hmmm...
More to follow!
Yeah.......
For a bush to be so deformed makes me think that this car has been subjected to some serious wheelspinning.....
I wouldn't reuse they arms for that reason. Fatigue here leads to failure.
Furthermore, the holes in the axle pickup brackets....are these elongated?
- shaunroche
Curiously it was only the offside that was deformed, the other side was perfect....
The mounting points looked fine too.
It's going on a welding jig tonight so I'll have better access to look at the mounting points then.....
Fairly typical of a Sprint after a few miles.
Must have rear end steered interestingly on power on and off...
Sometimes the bolts rust in and sometimes they pop out like they just went in. I've stopped looking for reasons now, but they always go back in with copaslip.
Its worked so far on the few repeats I've done. the front one is usually ok as this is undone for shock changes. The axle end can be a mare.
I also wouldn't polybush these as they do crack sometimes.
- shaunroche
Things are starting to happen now.....finally made it to the welders......
Nearly there....
So pleased my bespoke wooden wheeled wonder didn't collapse despite navigating some of Cheshire's bumpier roads!
Just got to get it back now!
Many, many thanks to PaulB transportation services and your Brill trailer! Cheers Paul!
Nearly there....
- shaunroche
A crap picture, but the subframe ' s nearly done!
I haven't got a torque wrench that will go up to 300Nm+, so torqued the new stub axles upto about 220Nm and carried on for 'a bit '!
Does this amount of thread poking through look about right, Remember it's a new shaft which I don't think are quite as long as original ones are they?.....
- SprintMWU773V
Looks fantastic. What did you use to get the old bushes out/get the new ones in? I was pondering the purchase of a press but actually for the amount it would be used it'd be quite expensive and they get in the way.
I used a piece of 3" pipe cut down on one side and a suitably sized socket on the other in a vice - worked a treat, without the need for a press.
1976 Taihiti Sprint
2024 volvo XC90 T8 Hybrid
2021 Toyota Yaris GR-Four
2015 Audi RS4 Avant (V8!!)
