Re: Project Little Green Dolly
Posted: Wed Aug 19, 2015 4:59 pm
Dolomite pushed out into the light of day and spanner wielding commenced!
Like every other Triumph bumper end cap I have come across, this one had exactly the same seized bolts which resulted in the captive nut not being captive in any way shape or form.
The other bumper nuts and bolts were as tight as a tight thing and I had not the strength to undo them.
Not to be deterred, I had a few mouthfulls of Barr's finest Bubble Gum fizzy pop and loaded with E numbers I ripped out the petrol tank.
It was quite easy seeing as the lazy fecker who did the welding of the recess that the tank sits in hadn't bothered to actually bolt the tank back in. It was just 4 small bolts FFS, not difficult.
All I had to do was drain the tank, undo 3 jubilee clips, give the tank a wiggle and out it came.
The tank is in good order. The recess is a mix of patch, paper thin original metal and a bit of filler.
The passenger footwell has been patched with a flat piece of sheet steel which is poo. Very, very luckily I already have a footwell panel in the garage that would be perfect.
I did try to remove the seats but for whatever reason, none of the sockets I had were correct, seat sorting now on hold until after the weekend.
I am now knackered and could have quite happily fallen asleep on my thick foam mat located under the arse end of the car.
Alun, you have a PM.
Ken
Ken
