Here you go, the codes are for red hoses but it will give you the sizes, hopefully you can work out which goes where from the previous photos I sent you.
I am sure I had atleast 1 straight joiner & 1 elbow left over, but can't remember which bits, so try to work it out for yourself & I am sure with the EWP some bits will be different.
I also used the same hose for the servo vacuum pipe as the manufacturers assured it would be OK & 2 years on it is (although I haven't done huge mileage) so you need to make your own mind up on that one.
You also need to determine the hose outlet size on whatever header tank you are using this will determine the pipe required to the T piece in the bottom radiator hose.
Hope it helps.
