VGK Sprint Restoration
Re: VGK Sprint Restoration
Hi Jon
I just cleaned the manifold up with wire brushes and the other other bits I did in a blast cabinet. Degreased with panel wipe as I find that is better than a normal degreaser. Then three coats of an Ali appearance paint from Eastwood, quite pleased with the outcome.
The paint is OK to 300c so good for for most bits except exhaust bits
John
John
This is the suspension part that was found to be snapped,
It's the passenger side one that is damaged !
I thought it might be them and yes I have some! Because they fit to two things and are shimmed for camber control, it is important to match the shims up or the brackets break - as you have found!
Thanks for that tip as I didn't know that and there was only one shim behind it and two on the main bracket.
John
John
Hi Steve
If you let me know how much for the bits, be much appreciated
John
John
Does anyone know where to get the gaskets that sit between the manifold and carb mounting plates. Also why does the carb kit come with four gaskets for mounting the carbs to the carb mounting spacer.
- Flyfisherman
You will find the part no on rimmerbros website look under tr7 159871JTSprint wrote:Does anyone know where to get the gaskets that sit between the manifold and carb mounting plates. Also why does the carb kit come with four gaskets for mounting the carbs to the carb mounting spacer.
paul
Bit of emergency welding before subframe and bits goes off to get plastic coated
- Welding done new plate in
- image.jpeg (67.99 KiB) Viewed 5974 times
I think I asked before but does anyone have any of these available as one is broken and the other is worn. It's part of the upper wishbone assembly.
Its not a race and its looking good. Like the subframe all shiny keep up the good work
Thanks Rob, got a few bits cleaned, painted and back together.
Sorry, completely forgot about this, I'll dig out a couple of brackets and some shims (if I can find them) when I go in on Monday.
