Re: VA 276, Mimosa Sprint
Posted: Mon Nov 09, 2020 4:09 pm
Thanks Tony!
I have a couple of bits to wrap up on the rear seam but I'll do them when I do the final sweep though.
I believe a couple of people were about to tackle the A Post and windscreen surround repair so as it is next on the list of things to do I thought I would crack on with it.
From the outside we have this, I have marked out where I want to cut. The usual, cut the top of the wing off first to expose the A pillar and bulkhead. The rust has got right into the A pillar as well unfortunately. From the inside under the dash, the bulkhead is as bad as they get, not too much of a problem though.
Taking off the top of the wing and the outer windscreen surround exposes the extent of the rust.
It looks like a more complicated repair than it actually is. As with all rust repairs once you break them down into individual panels then it all seems much easier. It's easy for me to say, I have done a few of these already!
I have cut the top section of the bulkhead out and a small section of the A post. On early cars, the dash support is spot welded in, on later cars it is bolted in. Now they are out of the way it's easier to formulate a repair plan.
I'll start with the A pillar repair everything else sits on top of this. After that I can put a new gutter section on, then the section of the A post I removed for access, then a bulkhead repair section, finally the outer panel, which looking at it would be easier to repair then remove the one from the scuttle that I have and finally the wing top.
The a post repair is made in two sections then fitted to the car, apologies, I didn't take any photos of this. It's basically the back section and the side section, both welded together along the outer corner.
This section...
This section...
And after a coat of zinc primer... There are a couple of pinholes which will need to be removed (we don't want any water getting into the A post and top of the sill!)
Next the gutter, I may have a go at making a gutter section. They are not complicated, just lots of folds so I need to think about the fold order, not sure yet!
This section...
This section...
