Page 23 of 40
Re: NWL – Project Carmine Sprint
Posted: Tue Nov 10, 2015 10:04 pm
by James467
Don't regret being honest, I appreciate the honesty!!
There's no evidence that it's been repainted from black and no evidence in the receipts of a swap and believe me my history is comprehensive!!
According to the production record that I have seen and my heritage certificate, she was built on the 13th August 1980. The plant shut down on the 26th August 1980 so she was built less than two weeks before then end of production. So it's not a surprise that it's actually a TR7 cover on a dolomite back plate! Like Jonners said, you got what you got that late in production.
I'm happy it's supposed to be grey, I just want to get the shade nailed.
EDIT: That said, I believe the last car to be built at Canley was a yellow Spitfire. I don't know when the final Dolomite was built so it could have been a few days or a week before the plant was shut. I have the list of Sprint and 1850 chassis numbers between mine and the final one but no dates.
Posted: Tue Nov 10, 2015 10:19 pm
by Mahesh
Did a quick Google and it came back with an entry on the forum,
viewtopic.php?f=4&t=11296
References to BMC Dove Grey, but as you were replying on there, you probably know.
Posted: Tue Nov 10, 2015 10:32 pm
by James467
Ah brilliant, I was looking for that post. In that case I may have the wrong shade of grey, I've used a Ford dove grey. I'll have a look in the daylight, if I'm not 100% I can easily sand the pu coat off and just overspray it in BMC dove grey. No major disaster and it's not going to stop me rebuilding the head now. Thanks for bringing it up Pippin.
Posted: Tue Nov 10, 2015 11:16 pm
by Pippin
You're welcome. It would be unlike you not to have taken a "before" pic, so why don't you just compare the "after" colour with that?
Posted: Tue Nov 10, 2015 11:20 pm
by Mad Mart
When I restored JYD I'm sure I used Ford Dove Grey, which was very similar to the original colour...
Posted: Wed Nov 11, 2015 2:20 pm
by James467
Posted: Wed Nov 11, 2015 6:40 pm
by Jon Tilson
Sprints came out of the box with either grey or black airboxes, but Ive only ever seen TR7 ones in grey.
My Sprint is black...
That's also bizarrely an earlier TR7 airbox outer...the later ones that would have been contemporary had a vacuum or temperature controlled flap valve instead of the two open pipes. They really do seem to have been trawling in the barrel at the end of the line.
Nice job on the carbs but I would personally have waited until the manifold was on the engine before fitting them as it puts less
weight on the unc bolts that hold the manifold on, and you get better viz of water leaks and access to fix them with the carbs off.
You can always whack them off again no worries, or just fit them to the engine out of the car....loads of ways to skin a cat.
Posted: Wed Nov 11, 2015 7:04 pm
by James467
I'd like think this happened
"We've run out of Sprint air box covers"
"Just go into the TR7 warehouse and see what you can find!"
Re the carbs, I thought you'd say that so they aren't bolted up fully, just enough to hold them on properly!
Posted: Wed Nov 11, 2015 8:40 pm
by James467
Posted: Thu Nov 12, 2015 12:51 am
by Pippin
I'm pleased to see that the air box looks much nearer the original colour under natural light.
Posted: Thu Nov 12, 2015 2:01 pm
by James467
Thanks, when you all see it then we can pass final judgement, if I need to repaint it then I'll just repaint it.
In case you haven't seen my post in the Dolomite related section, I think a small post can easily get lost in there!
I'm laying the head components out for the photo which is useful because I can check if anything's missing! Low and behold I have lost a collet and need another pair!!
Will an 1850 pair fit a Sprint?
Part numbers are different, 154060 for a Sprint, 106663 for an 1850. But there's a seller on eBay saying 106663 fits a Sprint as well.
Posted: Thu Nov 12, 2015 5:07 pm
by Karlos
James467 wrote:
Nice use of food containers, I hope you cleaned them thoroughly as chicken tikka stains are a pain to remove!
Exemplary efforts!
Posted: Thu Nov 12, 2015 6:07 pm
by Jon Tilson
I would want to see them side by side before making that call....
The prospect of one falling out doesnt bare thinking about....
If you HAD to choose I'd maybe use them on the bucket shim side. The bucket shims are the same as 1850 ones.
Posted: Thu Nov 12, 2015 6:47 pm
by Mad Mart
I've got loads of spares James if used ones are ok?
Posted: Thu Nov 12, 2015 7:59 pm
by Pippin
Karlos wrote:Nice use of food containers, I hope you cleaned them thoroughly as chicken tikka stains are a pain to remove!
Knowing James, he probably put the food containers through an ultrasonic cleaner and/or mediablasted them before use!
