Haha, the food containers are from Waitrose, they are the ones you can put in the bottom of the bbq when you;re roasting, really cheap and available in various sizes!
Back to collets, this is a bit of a cut and paste with an edit to make more sense here from my question in the Dolomite Related section.
viewtopic.php?f=4&t=30006
Measured my inlet valve.
All the same apart from the stem dia - 7.12 on mine, 7.86 on an 1850
Top of valve to top of the hemispherical undercut where the collet fits is the same - 2.84 mm.
Max depth of hemispherical undercut, same - 6.27 mm dia,
Length along the valve stem of this hemispherical undercut, same - 2.48 mm
I also got some 1850 collets from Rimmers to test them and you can clearly see that the 1850 ones are bigger, looks like to accommodate the increased stem dia.
154060 (Sprint) on the left, 106663 on the right
You can see the Sprint collet fits the valve nice and snug. It's not worn, just moved slightly in the photo.
Whereas the 1850 collet on a Sprint valve does not
Sprint collet
1850 collet
Thanks Mart, yes if you have a couple of good used ones can I have them off you?
