Pauldaf44 wrote:the choke light which I just cant get to work
Pauldaf44 wrote:I sourced a Vitesse choke cable which share the T knob and cut it down to size.
That mine explain why mine isn't removable... I got a it confused with the manual saying "remove the choke knob". I ended up disconnecting at the carb and pulling the inner all the way out to get the the back of the instruments a while ago!Pauldaf44 wrote:Apart from the knob itself not being removable...
Yep that would be the only way to do it on a FWD with a vitesse cable. It works which is more than the old one did so im not complaining. I also find that the pull wont mount vertically as per the original rather it sit just off the horizontal. Is yours the same?james_r_lucas wrote:That mine explain why mine isn't removable... I got a it confused with the manual saying "remove the choke knob". I ended up disconnecting at the carb and pulling the inner all the way out to get the the back of the instruments a while ago!Pauldaf44 wrote:Apart from the knob itself not being removable...
Spitfire MKIII cam and twin carb it to make it a 1300TCjames_r_lucas wrote:Maybe time to stick a spitfire cam in there at the same time?
Well, it wasn't quite 2 hours, was it?james_r_lucas wrote:(I had the engin out in 2 hrs, 1 week of waiting for bearings etc, then had them replaced and the engine back in in a day.
No, that was the first time, when a) I didn't know what I was doing and b) I was replacing the gearboxOli_88 wrote:Well, it wasn't quite 2 hours, was it?james_r_lucas wrote:(I had the engin out in 2 hrs, 1 week of waiting for bearings etc, then had them replaced and the engine back in in a day.
Or are we not counting when I rode over and broke my knee some more?
And brake servo, I believe there are a couple of other differences tooHoward81 wrote:Spitfire MKIII cam and twin carb it to make it a 1300TCjames_r_lucas wrote:Maybe time to stick a spitfire cam in there at the same time?
