Many thanks for your help.JPB wrote:If you do use copper across the axle tubes, make a couple of coils at either end, between the cylinder union and the pipe where it's clamped to the tube, copper will fracture readily in this situation if it's expected to flex over a relatively short, straight length of a pipe.
I must admit that prior to joining this forum, and after many years as an MOT tester and MOT station owner I have never heard of this practice. In fact over the years I have replaced many brake pipes with copper in this very situation, and never thought any more of it.
You are undoubtably right, and as you have personal experience of this problem, I bow to your superior knowledge on this subject. I can see how this may occur, it's just that the amount of 'movement' from the cylinder in this situation must be very minute. If the brake is correctly adjusted, just how much does the cylinder 'move'. I can apprieciate that if you move a copper pipe to and fro over any length of time it will 'work harden' and finally fail. But does it move far enough in this situation to create a work hardened failure. From your experiences it obviously does. but it just goes to show how we can easily overlook something really simple which could lead to a diaster.
