But Vermillion is one of my favourite Dolomite colours
I'll let you off this time! Personally I wasn't sure about Vermillion when I bought it but its growing on me! SteveHoward81 wrote:Sorry I was posting from my phone earlier, must have mid-read something![]()
Is it? I thought it was a Gerry Anderson creation!Carledo wrote: BTW love your avatar pic, its that Russian air cushion/flying boat thing, (schramm something?) isn't it?
paulsprint wrote:It's your car you can do whatever you want to it. I think it's a great project. The car will still look the same , handle crap( by modern standards) and not stop all your doing is getting rid of some of the crap bits of these cars and replacing them with better engineered modern stuff.
I have also been looking into the mgf electric power steering when you put them side by side it looks quite do able. I intend to retain the orginal domite column adjustment, stalks and housing. Wiring looks a piece of cake as its a complete stand alone system. Road speed sensor with be a hall effect sensor reading the prop bolts. This gives a signal of aprox 115 hz at 30 mph. The engine speed in my case is easy as I will just use the tacho out from the EFI ecu. This is the next project after the EFI
Steve, that is the prefix(VA) and suffix (HEA) for a Sprint engine fitted for automatic transmission with no actual number.Carledo wrote:It just says VAHEA, is this a code for a recon or something?
Iknow of a few V6s in FWD apps like Vectras and Cavs that have let go suddenly and terminally, mostly because of timing belt failure (the belt is an absolute swine to change and very expensive to do with a transverse engine so gets neglected) or rear head gasket failure from undercooling of the back of the engine, again because of the transverse app. The NS fitting in the Omega seems to be much more reliable and is certainly much easier to work on so I'm not ruling out a V6 in the Carledo at a later date, the basic gearbox is the same and I'm sure the engine is short enough to fit comfortably, its just the width that might cause problems. The thought of 210bhp straight out of the box for a 3.2 IS pretty tempting though!sprint95m wrote: I don't know if it is common but I have heard of Vauxhall V6 engines suffering sudden complete failure. This happened to one
of my friends in a Vectra he had owned from new. He didn't bother investigating what actually caused the failure, instead deciding
to scrap the car. Now he is back to Ford.
