Outlaw Dolomite Sprint
maitretjak
Re: Outlaw Dolomite Sprint
#46 Post by maitretjak »
Yes, I am -- however, my sprint hasn't done a lot of miles with it (one illegal trip only)...
Mounting it needs a bit of customization to make it fit: shortening one section a bit, adding mount points.
DutchSprint
#47 Post by DutchSprint »
Look what the cat dragged in...
DutchSprint
#48 Post by DutchSprint »
I've been a bit lazy on the updates lately. But I thought we where almost finished after installing the new exhaust. But now it appears the head I bought via eBay is not as solid I thought. The holes for what we call tappet buses (?) are worn out, which makes the buses tilt slightly. So we decided to prepare a new head ourselves (luckily I had one on spare). Since saturday is the first show, we are hurrying to get it ready for then...
DutchSprint
#49 Post by DutchSprint »
It was hard working, but we managed to get it up and running once again... https://vimeo.com/125901921
DutchSprint
#50 Post by DutchSprint »
After several problems with the engine and a damaged cylinderhead and engine after one of the valves came loose, I made a hard decision: replacing the engine with something else. It had to be a reliable 2.0 16v, so I ended up with a RS2000 16v from Ford. We picked up the engine this morning, in the next few months we'll be working on fitting in the engine.
#51 Post by tony g »
Interesting, what gearbox are you planning on using?
DutchSprint
#52 Post by DutchSprint »
tony g wrote:Interesting, what gearbox are you planning on using?
Theoretically it would be possible to fit the original gearbox, but I'm planning on using the Sierra MT75 5-speed gearbox
