The mystery deepens.
I took some measurements today to compare with Roger's and a heap of photos.
The first thing that doesn't make sense to me is the impact of how the car is suspended . At the workshop it was on a hoist positioned under the jacking points and while the oil pump looked close to the rack clamp there was still a visible gap. So in that circumstance the subframe and engine are one and essentially dangling off the body held by the subframe mounts. The engine's position relative to the subframe is as ever though since it's bolted to it.
I jacked it up today and suspended the car on axle stands under the subframe. Completely different result - measured the pump to rack clamp gap with feeler gauges and it was around 25 thou. But wait how could it even vary? The rack is bolted to the sub frame and the engine is bolted to the subframe. I don't get that at all.
And then after taking other measurements and photos I lowered the car back on its wheels, rocked it a few times to settle everything and then squeezed under the front to measure the pump to rack clamp gap again. It was perhaps 50 thou.
Honestly freakin sick to death of this car and getting pretty close to selling it. Bear in mind I've replaced the engine mounts. This BS has been going on for several years on and off and is a prime reason why I barely ever drive it. Ergo what is the point even having it? Except you'd never sell it with the noise its making so on we have to go. Fun level = nil.
Other measurements :
subframe lip to sump lip NS 154mm, Rogers 160mm
subframe lip to sump lip OS 127mm, Rogers 135mm
gear box mount bracket to OD sump 42mm, Rogers old 45mm, new with Volvo mount 53mm (and guess what, mine has the volvo mount)
and
rack flange to solid mount spacing : OS 16mm, NS 14mm so the rack might be a bit offset but its just 1mm
and
remembering in posts of the past I've mentioned how one Gaz shock needs to be adjusted differently to the other to keep the car looking level....
…. base of shock to spring seat : NS 132mm, OS 143mm. Never had an explanation for this either.
I welcome suggestions because I basically have no firm theories on this. I don't see how these measurements can vary when everything is bolted together nor do I understand why this became a problem when it never used to be several years ago nor do I understand how I can have replaced every bloody part and it makes no difference at all. It's had new engine mounts and new gearbox mount and I've checked the subframe mounts etc etc
The engine mount plates are semi circle cut out to top and front. The mounts were supposedly NOS. Pictures below of various. Can they be put in upside down? Someone said not. Do they look right or knackered?
Bear in mind Roger took his measurements from an inspection pit with the car on its wheels so exact comparisons may or may not be valid I don't know. But what we can say if we ignore that is that Roger's relative engine position appears to be about 6mm higher on both sides. That would fix my problem for sure.
And his gearbox mounting is 53mm difference to my 42mm which means my gearbox is 11mm lower than his (remembering to question whether there is any effect from the different car conditions when measured). 11mm lower would be dropping the back of the engine with it which wouldn't be helping at all either. But how could that be...…… same substitute volvo mount in both cars ffs. Took a couple of shots of the mount and propshaft fyi - the two parts of the prop are pretty much in a straight line
I did also spin the rack from one limit to the other while the wheels were off the ground. Wouldn't say it was super smooth but it was ok; and nothing seemed to catch or grind
Help me before I burn this car for the insurance.
spotted this little dent inside the bonnet facing near the oil filler cap although not lined up with anything in fact....odd
stabiliser bar from underneath. weird bracket is for oil cooler
view of exhaust clearance
gear box mount
gear box mount
ns engine mount weird angle from front
ns engine mount from rear
ns rack mount
os engine mount from rear
view of propshaft
view of propshaft
oil pump vs rack clamp
view of shock body ref the measurement taken - ie from seat across threads vertically to end of tube
spline in bottom steering UJ. It has copperease on it. I think I did end up cutting and shaping this. you can see it clears
another spline shot
ridiculous photo to be honest but in centre you can just see UJ clamp nut and get an idea of how close it is to the bodywork....but it doesn't catch hen the car is on axle stands anyway
