Unobtanium and old core
Re: Unobtanium and old core
Sealed Beam 5 inch twin-filament headlights have suddenly become NLA .
Quartz Halogen with an H4 bulb is a semi-drop-in aftermarket replacement, but will need relay switching.
BR.
BR.
- Engine bay bulkhead pad.
Do you mean the sound/ heat insulation?
Yup
That is going to be ripped out sometime this week, as i'm soundproofing my car. Glad i read this nowtinweevil wrote:Yup
Still useful as a pattern for other people to make copies, same is true of the black yoga mat from under the back seat cushion....
I've been informed by Fitchetts that Sprint wheel studs (7/16 unf) are NLA any comments? Steve
spark flash guard for sprint dissie ?
(the plastic round shield that fits over the points)
rimmers have them as NLA.
are they getting rare ?
Centre caps on Sprint alloy wheels seem to be made from the most delicate metal known to man so is there any chance of those being re-manufactured out of something just a little more resilient...?!
Door lock buttons (if that is what they are called) need to be hoarded as they can become brittle and crack/snap if handled roughly...!!!
http://www.chriswitor.com/proddetail.php?prod=615888grifterkid wrote:Door lock buttons (if that is what they are called) need to be hoarded as they can become brittle and crack/snap if handled roughly...!!!
I'm 70% sure I have the hose mounts on my car and I definitely don't need them- Original inlet hose supports
- clutch master
- clutch slave
- starter motor including solenoid
- alternator
Tinweevil
Engine swapping it so I'll be using the clutch from the doner car
Engines for sale so I have starter motor to spare
according to Autosparks the multi-pin connector plug for the fascia warning cluster on the dash wiring loom is also NLA.
Re:
tinweevil wrote:I've bought drum retaining screws recently from my local factor, I'll check they are still available next time I'm there and get a stock if they are on the way out.
Tinweevil
The drum retaining screws would they be the size as used on a stag,if they are any of the stg suppliers sell them
- Flyfisherman
Re: Re:
Drum retension screw is fitted across the range of Triumph's - TR2/3, stag, herald, GT6, spitfire,2000 / 2500 and of coarse Dolly - part No. V5435 qty of 4 required.new to this wrote:tinweevil wrote:I've bought drum retaining screws recently from my local factor, I'll check they are still available next time I'm there and get a stock if they are on the way out.
Tinweevil
RBros & JPaddocks have them in stock if anybody whats any.
Paul
