Page 38 of 64
Posted: Wed May 11, 2016 9:10 am
by Mahesh
Typical,
- 20160511_085918_1462953782479.jpg (245.18 KiB) Viewed 567 times
I know its sacrilege, but the aftermarket jobs just don't look right,
- 20160511_080621_1462953782117.jpg (290.18 KiB) Viewed 567 times
- 20160511_081614_1462953782308.jpg (398.83 KiB) Viewed 567 times
Posted: Wed May 11, 2016 1:00 pm
by Jon Tilson
Aaaargh!.
Oh well they are fairly common....so an e/window conversion for you then...
Or you could do a different speaker location like the trim under the front parcel shelf at the sides...
Posted: Thu May 12, 2016 5:20 pm
by Mahesh
Needed a bit of rounding off,
Used a washer to marker pen the handle,
- 2016-05-12 16 33 09.jpg (220.82 KiB) Viewed 510 times
Unfortunately, I don't have a bench grinder and an engineers file is too slow,
- 20160512_170722.jpg (266.36 KiB) Viewed 510 times
Posted: Thu May 12, 2016 8:01 pm
by tony g
Posted: Fri May 13, 2016 9:17 am
by Mahesh
Getting better at handle chopping, second and last one, and therefore I encounter a problem,
The e-clip retaining flare did not survive the extraction in a good way and is flaking off,
- 20160513_090055.jpg (227.36 KiB) Viewed 482 times
Now either I heat up the shaft and hammer it, but the knob will not survive, or I drill the
shaft center and screw in a washer, third option get another handle and start again,
unless anyone can suggest otherwise?
Posted: Fri May 13, 2016 9:23 am
by James467
Install electric Windows!
Posted: Fri May 13, 2016 10:19 am
by Mahesh
I have considered that, but the handles do look nice,
If electric is done later, I will use the existing plastic escucheon and put in a
chrome toggle switch in the center, only prob is it means another door to frame
grommet which in turn means more holes.
Alternatively, these would fit,
- door handle.jpg (36.6 KiB) Viewed 477 times
- window handle images.jpg (28.87 KiB) Viewed 477 times
Would be a pain to wind/unwind the window.
And it's NOT GOING TO HAPPEN!
Posted: Fri May 13, 2016 10:26 am
by James467
Awwwww but they would go so well with those neon hoses!!!
Posted: Fri May 13, 2016 10:43 am
by tony g
Can you run a hacksaw cut around the groove and fit a smaller clip?
Posted: Fri May 13, 2016 12:36 pm
by oily66
Can you drill a small hole through the spindle then put a washer on and a split pin or something of that type to secure and keep the rotation?
Posted: Fri May 13, 2016 7:51 pm
by Jon Tilson
Or stop messing up handles and door cards and stick the speakers somewhere else....
(sorry)
Posted: Fri May 13, 2016 8:18 pm
I have a universal electric window kit for my Sprint (front only) A mate bought it for his Defender about 20 years ago and never fitted it. The Defender is long gone so I got the kit for free!
So I guess I can spare you a couple of handles!
I'm toying with the idea of using the entire loom from the Omega on my car, it may be a bit on the large side but that's better than being too small! And it has wiring and grommets and stuff for 4 door speakers, electric windows, central locking, courtesy lights etc etc etc/
Posted: Fri May 13, 2016 8:35 pm
by Mahesh
It's only two handles, I bought the door cards
with the cutouts from a club member (honest).
The front doors are the best place for the speakers,
unless you suggest otherwise (on the other hand
don't make a suggestion
) or was that the suggestion)
On the plus side I have done the front doors remote
central locking, useless for security but does stop
the keys clanking and scratching up around the locks.
Posted: Fri May 13, 2016 8:55 pm
by Mahesh
Thanks Steve,
I'm ok for handles at the moment, was the Omega central locking individual electric solenoids or BMW type with a central air pump, just curious.
Door grommets can be a pain, door side easy, frame not so.
- 2016-05-13 20.53.39.jpg (102.88 KiB) Viewed 785 times
Posted: Sat May 14, 2016 12:07 pm
by Mahesh
Gone with Tony's recommendation of another hacksaw cut, but I had to make the goove below the
original yet close as possible to the top of the shaft,
not the best of pics,
- 1989.jpg (114.44 KiB) Viewed 763 times
got an e-clip in, (original flew off) somewhere)
- 20160514_115317_1463223509911.jpg (164.1 KiB) Viewed 763 times
and the end result is a stubby originalish window winder handle,
- 20160514_115524_1463223509974.jpg (170.25 KiB) Viewed 763 times
Probably won't last that long.
