Project Satin Black - Help!!!!!!!!
Howard81
Re: Project Satin Black - Help!!!!!!!!
#61 Post by Howard81 »
Certainly looks like a bent valve to me! Probably got sticky due to being out of use for so long, then the piston bent it. Luckily there doesn't seem to be any damage! Replace the valve or simply whack on a spare head and you should be all set 8)
1962 Austin Mini (project)
1962 MGA 1600 Mark II
1965 Mobylette SP50 (project)
2001 Rover 75 2.5-litre V6
Purplebargeken
#62 Post by Purplebargeken »
The head is now with my mate. He found 4 more non-springy valve springs, hopefully I will be able to update things on Saturday.
Purplebargeken
#63 Post by Purplebargeken »
Just bought a Dremel type thingy from Lidl, should be ideal for cleaning up various Tolly engine bits.
DazasDolly
#64 Post by DazasDolly »
They do a cracking job Ken, I carefully cleaned up my fuse box etc with it, handy little tool :lol:
Darren
Purplebargeken
#65 Post by Purplebargeken »
Hmm, port matching to the gasket. Have been Googling and it looks possibly interesting.
Worthwhile or waste of time and effort. Answers on a forum sized postcard please.
Purplebargeken
#66 Post by Purplebargeken »
Well the plan today was meant to be: go to mate's place, collect head which was to be stripped, cleaned and put back together again. Reality?
My git of a mate made me do the work myself :roll: :lol:
So, with the aid of his valve spring compressor:
These were then all lined up in order, so that no mixing up occurred:
This was the state of most of the valves:
It looked like they had been coated in black paint or tar. Very odd.
It ties in with this earlier picture:
This is part way through the cleaning process:
The valves were all cleaned and lapped in using a couple of different grades of paste. Nice even outcome on the valve seats :D
The valve springs, collets and valve spring seats were all cleaned up and everything was refitted. More piccies to follow tomorrow of the finished article.
Just have to make a couple of gaskets, get new hoses and away we go.
It was actually very satisfying to have done it all today and I was pleased that my mate made me do it. A really good day!
#67 Post by Jon Tilson »
If you cabn afford it, its worth getting hardened exhaust valve seats. Depends how long you want to keep it amnd how hard you drive it I suppose...
Used to be about a tenner a seat and then machining cosst to ft them...probably about a ton all in...
What do others think with more ohv knowledge? My spit still has its lead memeory and has o/d so never revs that high.
Purplebargeken
#68 Post by Purplebargeken »
Hiya Jon, that would've been the way forward but cash is a bit tight at the moment. I'll have to stick with an additive at the moment, plus my mileage is never that extensive (sadly). I guess when I retire that should change lol++. Plus I now have the confidence to remove the head should I decide to go that way. I'd like to view this Tolly as a keeper, so who knows. Tollies have to be my favourite if I am honest.
I forgot to add that the valves were undamaged and all straight. From the amount of crud I am presuming they were just gummed up and with non-use, had just stuck solid.
Today will see the crowns getting a clean up (apart from round the edges :wink: ). A final wipe over and the on with the head.
Purplebargeken
#69 Post by Purplebargeken »
As promised, I went down to the garage and continued work on getting the cylinder head back in its rightful place.
First of all, more cleaning up of the piston crowns. This is the before picture:
Afterwards:
You can see that i got a little carried away on the first piston crown but heeded the advice given on the others.
Head gasket on after cleaning away the remnants of the old one:
There you go. The nuts are just finger tight for now, until I get the torque wrench out of the loft:
I just need the following items and I can carry on:
Water pump gasket (may just make one)
Rad hoses
New thermostat
Odds and sods of other hoses and clips
Oh, must flush the rad out!
Lord Tolly
#70 Post by Lord Tolly »
Almost there
well done
Fingers crossed Ken you will be up and running soon :D
#71 Post by DoloWIGHTY »
Splendid work Ken, a bit parky today as well so I know how difficult it can be to motivated to get out there and start twiddling you nuts (if you understand?)
Lord Tolly
#72 Post by Lord Tolly »
Tell me about it Alan I was outside today trying to make engine paint dry with a hairdryer :(
Oli_88
#73 Post by Oli_88 »
DoloWIGHTY wrote:Splendid work Ken, a bit parky today as well so I know how difficult it can be to motivated to get out there and start twiddling you nuts (if you understand?)
I must be young and daft then.
In no particular order today I achieved, handbrake adjustment, brake bleeding, changed steering rack gaiters and track rod ends, set the tracking, did the timing, permanently mounted the exhaust, changed the carb mounts, gearbox mounts and probably some other mucking about.
Oh and it moved under its own power. Only a few inches, but still...
Anyway, well done Ken!
Very satisfying to do these things yourself, isn't it?
Hit it.
#74 Post by soe8m »
Are you sure you have the right headgasket? You have a recessed engineblock and i do not see the tag on your headgasket.
#75 Post by soe8m »
I did zoom in the picture and it shows at cil 1 that the gasket is a normal one. :(
