AVO coilovers with seperatly adjustable bump and rebound.
the fronts will need a couple of spares fro the bottom end as the rose joint is smaller than a standard bush. the tops should fit a standard top plate with just the smallest amount of modifiaction. My rears are to fit the group 4 six link back end but You should be a ble to get rears to fit without to much trouble aswell.2F45T4U wrote:Wow! Are they a bolt on fit for the Dolomite?
They cost just shy of a grand. The shocks start at £70 a corner iirc for narrow bodied combined bump and rebound adjust,poly bushes,steel bodies. and go up £400 a corner if your feeling flush.2F45T4U wrote:How much is a set of those?
