Re: a couple of questions about brakes!
Posted: Mon Apr 17, 2017 8:48 pm
I still think wherever the caliper is the grabbing force is the same (given the same radius from the centre)
xvivalve wrote:Lever, fulcrum and load; the point at which the load is applied will make a huge difference, particularly so if it moves from one side of the fulcrum to the other despite the actual distance being small.soe8m wrote:Having drum brakes on your wheelbarrow will have the same effect.
(but yes, I take your point that the parts attached will want to rotate around the wheel in all cases)
