Page 5 of 7
Re: 1850 gremlins
Posted: Tue Sep 15, 2015 9:10 am
by tony g
Im wondering if the cam timing was put together wrong and the valves hit the pistons, then after adjusting the timing it looks like it was wrong again hence the double mark on the piston. Maybe after the head came off for the 3rd time the owner decided the head gasket would go again so sealed it up and hoped ?
Re: 1850 gremlins
Posted: Tue Sep 15, 2015 9:54 am
by Triumph1300
Tony, the marks look as if both valves have hit each piston, as if the timing was 180 degrees out.
I don't think it's the cause of the current noises
I couldn't inspect the head last night, cold and wet when it came off !
I'd appreciate a second set of eyes on it
Re: 1850 gremlins
Posted: Tue Sep 15, 2015 12:30 pm
by AlanH
Be worth looking to see how the valves sit in the head.
Re: 1850 gremlins
Posted: Tue Sep 15, 2015 4:05 pm
by Jon Tilson
This car ran recently but not that well, so I would suggest the valves are ok. By all means have them out and look at the seating etc but I suspect they will be new valves and this engine has suffered a chain failure recently causing the marks on the pistons.
You need to remove the crank pulley to get the timing gear off. Not too bad - I tend to do it by bracing a bar against a chassis leg and quick squirt on the starter.
You can then look at jackshaft play and as I said....if its bad look for another engine. If its not you can reassemble
the water pump and see how it feels as you turn the jackshaft by hand. Not often you get to do that on a slant...
Re: 1850 gremlins
Posted: Tue Sep 15, 2015 5:57 pm
by Triumph1300
The only time I heard the car running, it was missing, and knocking.
Things improved with elevated revs, but it wasn't a happy motor.
The knock was loudest from the pump cover, using a screwdriver, we've been digging deeper as we've found the evidence of issues.
The valves look clean down the port, but the liberal use of silicon, and radweld has made me suspicious
Re: 1850 gremlins
Posted: Wed Sep 16, 2015 12:45 pm
by Toledo Man
Bruce, have you got copies of the parts catalogue and factory workshop manual? They're available in PDF format for download on my BT Cloud storage.
Re: 1850 gremlins
Posted: Wed Sep 16, 2015 3:06 pm
by Triumph1300
Yep
Re: 1850 gremlins
Posted: Wed Sep 16, 2015 5:46 pm
by Toledo Man
HERE it is.
Fill yer boots!
Re: 1850 gremlins
Posted: Thu Sep 17, 2015 6:05 pm
by RJF_70
Have cleaned up piston tops today, the marks are almost identical on all four. Also could anyone please confirm if the sprint and 1850 share the same timing case / cover?
Cheers Rich
Re: 1850 gremlins
Posted: Thu Sep 17, 2015 6:20 pm
by mahony
Sprint and 1850 have different timing covers Rich .
Re: 1850 gremlins
Posted: Thu Sep 17, 2015 6:31 pm
by Toledo Man
The post-'76 parts catalogue gives different part numbers for the 1850 & Sprint timing chain covers.
Re: 1850 gremlins
Posted: Thu Sep 17, 2015 6:32 pm
by RJF_70
mahony wrote:Sprint and 1850 have different timing covers Rich .
Ah ok, in that case anyone know the part number on inside case of 1850 one? Mines not off yet.
Cheers Rich
Re: 1850 gremlins
Posted: Thu Sep 17, 2015 6:46 pm
by mahony
Rimmers has one second hand one part number UKC3644
http://www.rimmerbros.co.uk/Item--i-UKC3644U
Re: 1850 gremlins
Posted: Thu Sep 17, 2015 9:27 pm
by MIG Wielder
Hi Rich, This is the timing case I have here. Is this 1850 ?
Re: 1850 gremlins
Posted: Thu Sep 17, 2015 9:35 pm
by RJF_70
Hi Tony, that looks like it, will double check in morning as is my day off!
Thanks Rich
