VGK Sprint Restoration
Reg
Re: VGK Sprint Restoration
#61 Post by Reg »
Wow..that colour is gorgeous! :eyes4u:
JTSprint
#62 Post by JTSprint »
Love the colour too, just want to get it on the body too but the more I strip the more work I'm finding,!!!
JTSprint
#63 Post by JTSprint »
Been busy the last few weeks, every time I find a rust spot it turns out to be full of filler some times 10mm thick, grrrr !!
Cut all the headlight pods and inner sections out and made some of the bits of from scratch as cheaper, holes where cut out from within the wheel arches and required new panels to be fabricated.
Had a few rainy days, surprise !!! So built the 45's up on the manifold and pieced together the linkage which you need three hands for, minimum! Also made a start on the bonnet which like the rest of the car had holes hidden with filler so cut it out and patch panels made and welded in. (Thanks Mart for the tip on covering the paint stripper with bin bags, works well). I think by the amount of dents in it and the roof someone stored stuff on it for years.
Wing mounted holes for the bumper were cut out and welded. Finally etch primer aplied to the front of the dolly, once the bonnets done I will refit the subframe and engine, only six months later than I planned.
Bumper fixing point
Bumper fixing point
JTSprint
#64 Post by JTSprint »
More photos
Arch rust
Arch rust
Welding time
Welding time
Arch repair panel
Arch repair panel
Floor panel patch repair
JTSprint
#65 Post by JTSprint »
Just a few new photos of some of the stuff completed
Linkage done.
Linkage done.
Bonnet stripped ready for hours of prep due to loads of small dents.
Patch panel ready for welding
And more!!!
And more!!!
Hidden rust holes, hidden with filler
After paint stripping a coat of etch primer applied before the rain came again!!
Then the next
Then the next
First light panel in
Arch complete and under coated, not going to rust again
JTSprint
#66 Post by JTSprint »
Sorry about the order of the photos.
JTSprint
#67 Post by JTSprint »
Please be aware of spiders in your welding gloves they bite !! or you might end up like me with septicaemia and lines drawn over you hand to mark the level of infection. Left a nice hole in my hand which luckly has finally healed up but took about a month. :cry: :cry: :cry:
About a week
About a week
24hrs
24hrs
After 8hrs
After 8hrs
tinweevil
#68 Post by tinweevil »
Yikes! I wouldn't be surprised by that from one of our uɐǝpodıʇuɐ members but Bristol? That's far too close for my liking.
It looks like you're almost ready to fit the headlight panels so I'll suggest something I wish I'd thought of before I had a load of work done on our TC. The fixings for the headlight bowls, consider welding nuts to the rear of the retaining panels before they go in. I'm kicking myself for not getting that done on mine. I have no excuse, I hate using rivets and I had holes drilled & nuts welded for a 2nd fuse box on the inner wing. I should have made the connection. I'll have to use spire nuts and no matter how careful you are there's always a bit of paintwork damage with those.
JTSprint
#69 Post by JTSprint »
Thanks for the tip, there's a few places I wish I had done that.
new to this
#70 Post by new to this »
tinweevil wrote: Mon Oct 02, 2017 11:03 am Yikes! I wouldn't be surprised by that from one of our uɐǝpodıʇuɐ members but Bristol? That's far too close for my liking.
why not use rivet nuts
JTSprint
#71 Post by JTSprint »
Rivet nuts I never thought of, thanks could be very useful now all welded in!
Flyfisherman
#72 Post by Flyfisherman »
I did mine with rivet nuts - but the down side is that I had to make some brackets to go behind the headlight panels, there to held in place with rivet nuts - panels + brackets are powder coated.
viewtopic.php?f=4&t=32367&hilit=headlig ... ls#p300666
Paul
#73 Post by tony g »
I used rivnuts when I changed the bowls for better ones, bit fiddly but worth it :thumbsup:
JTSprint
#74 Post by JTSprint »
Made the most of the good weather and got the car finally back on its wheels. Sub frame, suspension and shocks all in.
Subframe
Subframe
#75 Post by Carledo »
OOOOOOH! Pretty!
