sprint eng rebuild
trackerjack
Re: sprint eng rebuild
#61 Post by trackerjack »
I have piles of aluminium to easily create the spacers that I will make, as I do I will photograph it, but I will only be making girdle for my own use as Ken has all the right parts and knowledge to sort you guys out (thanks for thinking I could though).
trackerjack
#62 Post by trackerjack »
Measuring for endfloat.
Dianes kitchen scales proved a weight acuracy of no more than 1 gram.
I lightened this flywheel 10 years ago and was careful to have radiused edges everywhere.
The standard one is shown for a comparison.
DF
#63 Post by DF »
trackerjack wrote:I have piles of aluminium to easily create the spacers that I will make, as I do I will photograph it, but I will only be making girdle for my own use as Ken has all the right parts and knowledge to sort you guys out (thanks for thinking I could though).
Im sure you will be able to do it
It will be very time consuming but if you have the time 8)
I just thought ken may be able to make some kits up as
he has all the dimensions allready if he wanted to .
March isnt very far away and i hope we can all get together at the start of the year
For a track day :D
trackerjack
#64 Post by trackerjack »
I reckon on spending 2 Days at the workshop this holiday to complete all the maching required Darren.
Yes I am reall looking forward to gettig back on track with you guys again, its been 3 or 4 years since I last saw you Darren.
Thanks for you suggestions too.
#65 Post by xvivalve »
Fair play and respect Jon =D>
OK Ken, whilst I'm told my engine is now back in the car, what is your 'retail' on one of these girdles?
trackerjack
#66 Post by trackerjack »
We often read about dodgy oil filters and that we should only use those with a raised lip and not ones with a stuck on washer..............this engine blocks oil outlet from the filter was alomost totally blocked by a loose filter washer remains...............once again our engines can be destroyed by something simple.
Be alert.................your Dolomite needs Lerts :D
newguy
#67 Post by newguy »
Looking good Jon
trackerjack
#68 Post by trackerjack »
Wot more boring pictures..............listen I had to go down tto the cold unheated factory so you lot can be bored :D
Marking out for the
bandsaw watch those fingers Ugene
using the machine to to accurately size the block which was true to .002"
More checking get this bit wrong and the whole time is wasted I logged all the hole positions so the machine just gets on with it.
trackerjack
#69 Post by trackerjack »
just a light cut on the main caps so that the supports do just that.......support.
Time to play the fool while the CNC drills all the support bracket holes (when you get old you either get grumpy or mad)
Safety specs on previous pic and safety shoe here health and safety at all times :D
never cut right through cos it makes a mess and the plate could break the cutter
using a parallel to check that the dimensions are right........ :woohoo: of course they are :wink:
the finished item with the alloy supports machined to support the centre of caps.
I do not know what others have done but I made the ladder frame compress the mains by .003" so the bolts are not pulling on the block, I also doweled it in 4 places (2 each side) to maintain accuracy.
The whole job took 8 hours to complete but it should give me some peace of mind that maybe some other problem other than a cracked block will kill this engine when complete.
Oli_88
#70 Post by Oli_88 »
Pure filth that is. Loving it.
Makes me wish I still had my machining job... Almost.
Hit it.
trackerjack
#71 Post by trackerjack »
What are you doing up so late :D
Oli_88
#72 Post by Oli_88 »
trackerjack wrote:What are you doing up so late :D
Watching an utterly awful film. Drifting. Pfft. What a waste of tyres.
Could say the same to you... :P
Hit it.
trackerjack
#73 Post by trackerjack »
I had an office job and gave it up. I was the buyer for the largest toolmaking company left in the UK, most of the people I dealt with were women and I have to admit that I enjoyed it but the job kept expanding into checking all invoices were correct, then entertaining customers, it got so bad in the end I was absolutely flat out all day...............sod titles and a suit I went right back to my beginings....................making things :D
trackerjack
#74 Post by trackerjack »
THat must be that bloody Vin Diesel crap................the young will believe anything :D
Oli_88
#75 Post by Oli_88 »
Got it in one. Number 4 is out this year... Joy. Though I did spot an RS200 in the trailer. Quite a rare piece of plastic to see on film these days.
Sat at a computer will do for now, leaving the fun stuff for the weekends... Though right now it's more bike and other peoples car related, than Dolly tweaking.
Soon my pretty, soon.
Hit it.
