The resurrection of KSF404T - 1978 Sprint
Re: The resurrection of KSF404T - 1979 Sprint
#61 Post by xvivalve »
Good bloke!
tinweevil
#62 Post by tinweevil »
Top stuff and well done that man. Lots of pics & progress updates please.
triple tango
#63 Post by triple tango »
I will detail the rebuild on this thread.
I've never liked travelling through London & it sure was hot today. No air-con in my truck.
#64 Post by Toledo Man »
Roy's a top bloke. When I did the TC conversion on Snowdrop I needed a throttle cable so he sent me one through the post at no extra cost.
I hope there's no damage to the pistons when the head comes off.
Howard81
Re: The resurrection of KSF404T - 1978 Sprint
#65 Post by Howard81 »
Come on Roy, air conditioning?!? I thought you were a hardened Sprint driver :mrgreen:
Seriously though, last summer I had one of those powered hand fans in the glovebox! But KSF has always coped with the London traffic very well, and never really got too hot.
Looking forward to the updates :)
1962 Austin Mini (project)
1962 MGA 1600 Mark II
1965 Mobylette SP50 (project)
2001 Rover 75 2.5-litre V6
triple tango
#66 Post by triple tango »
UPDATE
All stripped. The 2 little cam sprocket bolts had sheared, no obvious piston/valve contact. Very lucky ! :D
Head gasket was just starting to blow.
Home made water pump slide hammer.
Howard81
#67 Post by Howard81 »
Cor, that is lucky!
What with the worn water pump and head gasket, it would probably have needed work done on it anyway.
I will await the shopping list :mrgreen:
Roy, can you see any engine number on the block? The V5 still has the original one on it. I've never been able to find one on the current engine, but I've heard some replacement blocks didn't have any.
triple tango
#68 Post by triple tango »
all cleaned up ok, no damage
another home made tool for brass cage removal
found half a bolt head in the sump while fishing with a magnet, I'd really recomend pulling engine out, removing sump & having a good clean inside.
Howard81
#69 Post by Howard81 »
triplecustard wrote:found half a bolt head in the sump while fishing with a magnet, I'd really recomend pulling engine out, removing sump & having a good clean inside.
:shock:
How on earth did that get in there, and more importantly, where is the other half? :o Maybe the cause of the rattling noise I had?
Engine out? If you say it needs it, go for it, better safe than sorry :)
triple tango
#70 Post by triple tango »
bits of bolts & swarf from chewed up cam sprocket bolts - I couldn't find the tab washer!
Everything checks out fine;
I've removed & checked all 16 valves, non bent just carboned up & needing reseating.
Pistons & bores all fine.
Jackshaft bearing fine.
Cam bearings fine.
Shopping list;
water pump & L/H thread bolt
full gasket set inc seals plus extra cam cover gaskets for future re-torqueing
exhaust downpipe gasket
timing chain, tensioner,
cam sprocket (holes chewed up) bolts & tab washer
club plug tubes
plug leads
oil & filter (screw on type)
engine rubber mounts need replaceing too
Howard81
#71 Post by Howard81 »
Thanks Roy, I've sent you a PM :D
#72 Post by Toledo Man »
Glad to hear there's no valve or piston damage. KSF is in good hands. Keep us posted Roy.
tinweevil
#73 Post by tinweevil »
Good news on a sprint engine strip down makes a pleasant change.
New pump :shock: what was the problem with the old one? Don't forget the pump block bush.
How did you clean the pistons so completely and quickly Roy? For the valves I read somewhere oven cleaner saves using mechanical methods, anyone ever tried it?
Tin
triple tango
#74 Post by triple tango »
tinweevil wrote:New pump :shock: what was the problem with the old one? Don't forget the pump block bush.
How did you clean the pistons so completely and quickly Roy? Tin
Bottom of shaft was worn, yes a bush too Howard please! I knew if I posted the list someone would notice something I'd forgoten, thanks.
Pistons cleaned ever so easy as its recently had a recon block.
triple tango
#75 Post by triple tango »
here's the tab washer, mashed into the bottom pulley
