Justyns 1967 1300FWD
Re: 1967 1300FWD Resto
IIRC I feed the wire down through the inside edge of the screen rubber and into the boot to connect brake light wire where it comes of the dimmer relay area.wasn't too difficult just a bit fiddly and time consuming.
There's a fair few loose wires in the boot. I will have to do some head scratching nearer the time for me to actually take real notice of them.
Loose wire in the boot could be from the reversing lights, the stop light that was mounted on the parcel shelve and iirc there was a fog light which i removed.
Probably the most frustrating bit of the bodywork will be to try and improve the line up of the bonnet somehow.
Picked up an ebay buy today:
Very solid bonnet - solid+++ in the usual problem places
Complete dash
CV Joint
Rotoflex
Ball joint
Ball joint repair kits x 4
Handbrake cable
Complete clutch
Rotoflex
Pitman book of the 1300 fwd
Pair of new shocks
Headlights, chrome rings and cowls
Rear wheel bearings
Rad hoses x 3
Plus some oher little odds and sods
£100
Tomorrow will see work commence on the final removal of the rear bumper/towing bracket, removal of the small amount of remaining paint, rust killing and primer coat applying. Hopefully!
Complete dash
CV Joint
Rotoflex
Ball joint
Handbrake cable
Complete clutch
Rotoflex
Pair of new shocks
Rear wheel bearings
Rad hoses x 3
£100
Seen it already Malc. It's about £3799 over my budget
LD would be very jealous.
Well whaddya know. Tried several times to access the garage today to crack on with the FWD. Can't get close because some knob jockey has decided to park his VW whatever across the front of the garage. No-one in the flats knows who it belongs to. A wasted day. How marvellous.
How problematic is expanding foam up the tailpipe I wonder? Just a theoretical question you understand.
Let a tyre down, place a note under the wiper "noticed you had a flatty, call me on my mobile 07xxxxxxxxx and you can borrow my pump". Then when they call you you can tell em they shud no be parking there"
Not problematic enough in the circumstances, Ken!Ken R wrote:How problematic is expanding foam up the tailpipe I wonder? Just a theoretical question you understand.
Now, if, and strictly theoretically of course, some random person were to crouch beneath the front of his car and attach a nut to one of his fan blades with a 2 ft length of nylon monofil or similar, with the lightest breaking strain value that can be found, then the inconsiderate badstart would soon get the message and the length of the line would mean that his radiator wouldn't burst until he'd at least cleared the door.
The random person shouldn't use string; it doesn't pull cleanly off when the nut contacts the radiator, and so leaves evidence of what caused the sudden and otherwise inexplicable leak.
Thinks... Golf you say? Then it's an electric fan so the car would get quite some distance before the fan cut in.
- NickMorgan
I suppose it could mean that the VW remains there even longer! Best just to scratch a message on the bonnet asking him not to park there again!Ken R wrote:How problematic is expanding foam up the tailpipe I wonder? Just a theoretical question you understand.
Thanks Photobucket
Thanks. Plenty of food for thought. I will also leave a big note on the garage door and take a day off this week to catch up.
Like the nut and fishing line...... very devious indeed.
