Thanks for all the help and information about setting up my carb guys (never touched an SU carb setup before)
Rob
Hope your trailing arms go better than my effort last week! took nearly all day to do one trailing arm!boybiffa wrote:been busy today ordering a few small parts..
1) Rocker cover gasket (going to check the valve clearances and re-set the gaps)
2)throttle cable (current one is really frayed at the carb end of things)
3) Carb linkage ball socket ends (currently is being held together with wire)
4) steering column support bush retaining plate (current one is all elongated causing in a slapping affect through the steering column and wheel) New plate should sharpen things up.
Hopefully if the parts above come tomorrow or monday morning,everything will be sorted
monday's plans are...
Replace all the rear axle bushes - radius arm bushes (tie bar bushes) trailing arm bushes (as current ones are knackered)
I know It could be down to timing scatter or dwell angle etc (this will be checked out on monday (providing the fitting of those rear bushes don't take too long)
Rob
