Several have now raised the issue about getting the steering wheel in the right position so that the car is tracking straight ahead.
I have attempted to do exactly as the workshop manual tells us what to do in and I shall quote directly from the manual itself but I have missed describing a step which I undertook when I cleaned and overhauled the steering rack.
The instructions from the workshop manual are as follows:
1. Locate the car on level ground and position the front wheels in the straight-ahead position.
2. Using wheel alignment equipment, check the front wheel for toe-in. Four requirements should be met:
a) Steering wheel centralised.
b) Steering rack centralised.
c) Front wheels parallel to 1/16 in (1.59 mm) toe-in.
d) Front centres of both tie-rods equal.
In order to meet requirement a) the little metal tang that clips onto the steering column, seen in the photo in my previous posting, the right hand arrow, needs to be sitting at that three o’clock position if the indicators are to cancel correctly. The steering wheel should and can now be mounted as if the car is pointing straight ahead.
To meet requirement b) the steering rack was centralised before I installed it back in the car and it was locked in that position using a bolt screwed in temporarily into the rack housing.
Then the intermediate shaft was installed.
So the position of the steering wheel in relation to the centre of the rack should be correct. In doing so I will have satisfied requirements a) and b).
What I have neglected to do is to explain that prior to installing the steering rack into the subframe I mounted the tie-rod outer ball joints and set them at what I determined the correct measurement was, as shown below.
- 20121204Pw Steering rack.JPG (44.08 KiB) Viewed 4457 times
The workshop manual describes this in an earlier instruction. Quite how we are expected to measure the nominated centre to centre distance of 9 and 3/16th of an inch is a little beyond me but if even if you get close and get the same dimension side to side then it is very likely that the car will track straight ahead even if the toe-in measurement is incorrect.
I rather suspect too that when the cars were assembled on the assembly line the steering racks were set up with the outer tie-rod ends installed and would have been done in some form of jig which would have given the measurement shown.
I think the important thing to note though is that once the steering column has been centralised and connected to the steering rack, in its centralised position, any adjustments to centre the steering wheel and to correct the toe-in are done by loosening the locknuts #1 and the gaiter clamps #5 in the factory illustration and winding both inner tie-rod ends in or out an equal distance (to correct the position of the steering wheel) or in or out on either side to adjust the toe-in.
If you disturb the relationship of the intermediate shaft couplings to the steering column and or the steering rack then the steering rack will not necessarily be in its central position when the car is tracking straight ahead.
I believe all adjustments should be made on the inner tie-rod ends only.
I will check the toe-in manually when the car is complete and full of fluids and the suspension has settled down to its normal ride height. It can be a fairly time consuming task but I will, in due course, take my car to an alignment specialist who will check not only the toe in but also the castor and camber and to see, in my case, just how accurate Brian’s welding was when he joined the two car halves together. If the specialist has to make any adjustments they will be made on the inner tie-rod ends, leaving the steering wheel set at the straight ahead position.
