Re: New Gilbert
Posted: Wed Jun 03, 2015 12:03 am
Rang up Garage to book MOT for Friday this afternoon and the Guy said he had nothing on at the moment so bring it straight round, so I did! Oh crap, it was not finished, I forgot to fit one of the pins that hold the brake pads in place on front disc's. I left it out as I had miss laid the 'R' clip so I thought I would do it later....... Told the Guy who said no problem as he would do it when checking the wheel, nice Guy I thought, then he said one of the front side lights was not working!!!! Bugger, it was working the previous week. Anyway, he was really interested in the car as he used to own a Dolly Sprint when he was courting and he sold it to buy an engagement ring. I asked him if was worth the swap and he said yes, but the Dolly would probably be worth more today........ Anyway he said everything was fine except the sidelight and handed me a Phillips to put it right. Took lens off and waddled the bulb and checked the bullet connectors and still no light so took out working bulb and swapped it over and it worked so bulb blown. Guy gave me a new one and put it in the working side when I brought the car in and it did not work! Messed about for 5 minutes and the Guy got fed up and said, it was working when it came in so put the lens back on and be on my way.
So passed MOT with no advisories - after all the hard work over 18 months, many hours getting rid of rust, welding nearly 3 sheets of 2m x 1m x 0.9 Zintec repairing the holes and new sills and door bottoms from TDC, I lost count of the number of weld wire reels I used, stripping down every last nut and bolt down, spraying etc, etc etc. Many people have done this before, but it is not until you do it yourself do you realise the enormity of the task and the amount of work and dedication involved. After seeing the quality of the Triumph cars at the Coventry Motofest, mine is not of that standard, but I am very pleased with the result and I still have loads of work to do - fit exterior brightwork, fit underfelt and carpets, replace hardboard on door cards and fit, fit parcel shelf and cut-in and polish paint which I have not done yet. Thought I would leave it to last in case of damage during assembly, good job as loads of little nicks to be dealt with. Fitted the outer door locks today and found that you can lock and un-lock with any key and if partially in or not! New ones needed as well as better front bumper and overiders, rear ones will need re-chroming some time. So lots of jobs to do but at least I can take it out for ride in-between doing them. Took wife out for a meal at local pub tonight as a thank you for putting up with me and my tantrums with the car, she loved the car. We had a 1969 1300TC a year before we got married and had it for 14 years and loved the car so happy memories. TNX 472 G funny how you remember certain numbers?
