Page 6 of 6
Re: 1974 Spitfire MKIV.
Posted: Fri Sep 11, 2015 3:14 pm
by matienzo
IMHO lowering a Spitfire for road use gains precisely zero benefits. They are so low anyway you end up struggling over anything but a flat road! You can gain a good road set up with standard height and uprated springs and/or shocks. Let the suspension settle as Toledo Man says but if you end up with too much settlement you'll end up with road clearance problems.
Posted: Mon Sep 14, 2015 3:21 pm
by Jon Tilson
Indeed a Spit is quite low enough as it is....
To correct an earlier poster the front trunions should be filled with gear oil, not engine oil.
Even the OE rear springs start to sag after 50k miles or so...I dont think a Spit rear spring is ever fit and forget.
Mine is on its 3rd...
Posted: Tue Sep 15, 2015 11:52 am
by matienzo
Fit and forget as in not having to replace the replacement after six months Jonners. The new springs from BCC are made from scratch in the UK and are carefully tempered according to the BCC chap I spoke with at the TSSC International. I've no reason to doubt this at this stage.
Posted: Thu Sep 17, 2015 5:44 am
by Dolly-Dimple
Nice to see this coming on, I used to have a P reg Topaz 1500 - great fun little cars :-) All the best with it.
Kind Regards
Russell.
Posted: Thu Sep 17, 2015 8:15 pm
by Howard81
I'm not sure a lowered Spitfire is possible.. I lose enough rear exhaust clamps as it is!
Keep up the good work on the resto :D
Posted: Thu Sep 17, 2015 9:31 pm
by cliftyhanger
Our spit has a 3/4" lowering block on the rear, and an old GT6 spring. Sits low but absolutely no ground clearance issues. At the front it is pretty low too. I am running hard front springs and the front tyres just about touch teh wheelarches,, I had to use 10mm thick spacers to stop contact. Again no clearance issues.
The car has just been around Europe, many alpine passes including Slovenia where cobbled hairpins appear to be normal. And many of the roads in Eastern Europe where worse than Uk roads (east germany was particularly bad, czech republic wasn't good)
So yes, a lowered spit is very feasible and perfectly practical. We were not pussyfooting about. Just pay attention to detail and get the exhaust and so on nicely tucked up and correctly mounted. No dangly bits!
Posted: Fri Sep 18, 2015 8:58 am
by wiggybum
My dad fitted a pair of new lotus trunnions to his Spitty from Canley Classics:
http://www.canleyclassics.com/suspensio ... ension-kit
No more messy gear oil in grease guns.
Posted: Fri Sep 18, 2015 4:38 pm
by Jon Tilson
Nice but not cheap.....
I did think about it after I had one vertical link snap its bottom thread...
Posted: Sat Sep 19, 2015 8:14 am
by wiggybum
I agree - after having one snap while touring in europe,it's a cost effective investment! The steering is better with them too and it's nice to " fit and forget ".
Posted: Sat Sep 19, 2015 9:34 pm
by cliftyhanger
I bought them too. And for me to fork out that amount.....
However, when compared to buying a new pair of std uprights and trunnions the difference is not as big as you may think :wink:
After all, who really likes the idea of 40 plus year old uprights that have lead a miserable life?
Posted: Tue Mar 01, 2016 7:39 pm
by louisw
Sorry i've not been very active recently! Life's been catching upto me with university work and the like! I recently purchased a little 1.2 clio as well which has seen me getting back onto the road after nearly 2 years of passing my test and not driving. Going home this weekend and hope to complete nearly all the welding on the spitfire and get the rear brakes sorted. That's if it's dry...
Hopefully post more again soon. :)
