Thanks! I spotted one of them, I'll try and find the other now you've pointed out there are 2!
RUK - Project Recommission 1972 'Dolomite' Auto
- yorkshire_spam
Re: RUK - Project Recommission 1972 'Dolomite' Auto
- yorkshire_spam
One step forward 2 steps backwards at the moment with the Dolomite. I really need her back on the road ready for the house move, but she's fighting me all the way!
I faced a bit of a dilemma with the ignition switch issues, I have a couple of later spare units, but they are "3mm connector loom" parts. Being an early(ish) car Binny has the molded 4.5mm pin loom connectors.
Of course I could cut the connector off the original switch and splice it onto the new one (or even get a 3mm pin socket and make a short adapter loom) OR de-solder the pins at the switch and solder on the old loom. Neither option would be totally satisfying to me.
The early switches with 4.5mm pin loom seem pretty rare, but Mick Dolphin came through with one for me!
I fought for a while trying to feed the loom back down the steering column with it in place, but it's just too tight (I managed to pull the old one out and drag a line through to try and pull the new one back - too tight though!)
So I pulled the steering column out. Frankly I wish I'd done that in the first place as it was an easy job getting it out and makes changing the switch a piece of cake.
Sadly (now the 2 steps back) on removing the loom cover that fits under the steering I found the lighting loom badly melted. I'm surprised it didn't cause a short/fire!
Again, being a 4.5mm pin loom connector... I can't just make up a replacement loom for this, which has left me chasing a replacement. Mick Dolphin doesn't have one, but Fitchetts do, so now I'm waiting for that to come before I re-fit everything.
It's a shame there's no compatible replacements for the 4.5mm pin connectors - if there was I could have solved all this a lot quicker/easier.
The early connectors are getting harder to find now, the parts you need are the same for Stags, gives you more chance of finding the parts you need, i know you've got parts now but would have been quicker to solder your loom connectors on the new switches, good luck
- yorkshire_spam
Thanks for the heads up Dave! As far as I can see there are no compatible connectors anywhere out there - so it's NOS or used parts only!new to this wrote: ↑Wed Aug 02, 2023 6:23 pm The early connectors are getting harder to find now, the parts you need are the same for Stags, gives you more chance of finding the parts you need, i know you've got parts now but would have been quicker to solder your loom connectors on the new switches, good luck
Just had a thought, AutoSparks sell looms for early cars maybe they mite sell you the connectorsyorkshire_spam wrote: ↑Wed Aug 02, 2023 9:01 pmThanks for the heads up Dave! As far as I can see there are no compatible connectors anywhere out there - so it's NOS or used parts only!new to this wrote: ↑Wed Aug 02, 2023 6:23 pm The early connectors are getting harder to find now, the parts you need are the same for Stags, gives you more chance of finding the parts you need, i know you've got parts now but would have been quicker to solder your loom connectors on the new switches, good luck
Aye....
They switches are common to 2000s (up to about 1973),
please have a look at....
https://www.chriswitor.com/products.php?cat=276
https://www.chriswitor.com/products.php?cat=277
Chris has secondhand in stock.
Ian
Ian
- yorkshire_spam
Re: Aye....
Thanks Ian, I'll take a look when/if I need anything in future.sprint95m wrote: ↑Wed Aug 02, 2023 10:32 pm They switches are common to 2000s (up to about 1973),
Ian
That's a good spot! They don't list them as parts, but the loom photos clearly show the correct encapsulated/potted 4.5mm pins/sockets. I'll see if they'd sell the pins/sockets separately.new to this wrote: ↑Wed Aug 02, 2023 10:18 pm Just had a thought, AutoSparks sell looms for early cars maybe they mite sell you the connectors
It'd be a PITA making the encapsulation and ensuring correct alignment to the corresponding connector - but totally do-able with some polyurethane potting compound.
Cheers, Sam
- yorkshire_spam
By way of an update the lighting "mini-loom" arrived from Fitchetts today, so the whole lot can go back together now!
- yorkshire_spam
Enquiries with autosparks revealed that they do list the crimp terminals used in the encapsulated/potted connectors
Moulded Plug Socket Terminal Part Number: 150555
Moulded Plug Pin Terminal Part Number: 150558
I now have some and they do appear to be a good match for the pins in the connector - which means that if I create a mold for them I can actually replace the connectors/looms now. (Non-trivial task I know, but at least it's POSSIBLE!)
- yorkshire_spam
MOT Passed! Another year of motoring. A few minor things to check, tester commented on slight play in the NS end of the steering rack and in the steering UJ. Also need to check the end-float/play in the wheel bearings.
- yorkshire_spam
I came to start the car on Monday in preparation for using the car for a work trip on Wednesday this week - nothing, dead battery. No amount of slow charge/fast charge/boost start could give it enough "ooomph" to get the car started.
Late on Tuesday I gave up and ordered a new battery, which has just arrived (I opted for delivery today knowing I was out at work yesterday) I nipped out at lunch time and swapped the battery onto the car. Starts first time!
I think the car is sulking because the Spitfire has had most of the attention this year in preparation for the RBRR etc.
- yorkshire_spam
She's definitely sulking about something... tried to take the car out for a run last night and got to the end of the street and a serious mis-fire under load developed. Hmmm another problem that needs solving before the house move!
- yorkshire_spam
Sodding car. I fired her up on Saturday morning and she was ticking over fine, but any attempt to rev resulted in a nasty mis-fire no matter what the choke setting. I left the car to warm up and things seemed to improve. Switched off, went inside did a few other things. Came back out... car fired up fine and rev'd no problem and has done (including several runs out) all weekend.yorkshire_spam wrote: ↑Thu Nov 09, 2023 9:10 am She's definitely sulking about something... tried to take the car out for a run last night and got to the end of the street and a serious mis-fire under load developed. Hmmm another problem that needs solving before the house move!
I hate intermittent issues. My only hope is that the warm through and running has actually cured whatever it was (damp in the ignition system, sooted up plugs, something like that)
Oh…
First thought was condenser but as it is an early Dolomite I would try bypassing the tachometer…?
Ian
Ian
- yorkshire_spam
Re: Oh…
That's a genius suggestion Ian! Thanks - hadn't even occurred to me, but now you say it....DOH!
No condenser as James fitted an electronic ignition - one of the items I've been checking to rule in/out is the connections to that which were disturbed taking the engine/box out and refitting. But they seem ok.
