Bottom ball joint now a thing of the past :-)
Posted: Wed May 27, 2009 2:43 pm
After having trouble with the bottom ball joint nut and arm touching my
Discs on hard cornering i have replaced the bottom arm and ball joint
The old set up was at the limits of its travel as i have my car quite
low
This is how the ball joint sat on my car and touched the disc on very hard cornering
I have used 5/8 rose joints and solid aircraft quality stainlees steel rod as i wanted strength and reliability over weight saving as i use the car more on the road than track and having to do an emergency stop in the pot holed british roads
will give them a beating
I still have a bit of work to do with the spacing of the joints but hope to have it on for coombe
So easy to set your camber up as well
