Where's the best place to buy them (assuming they are still available)?
I'm in particular need of the rubber surrounds on the front quarterlights.
Window Seals
Bill,.........
Is it the channel type seal that the glass slides up and down in, that you require?
If so, buy it from T2000 specialist Chris Witor, since he sells the correct profile for Dolomites (same as 2000/2500).
Re: Window Seals
ive recently fitted front quarterlights which are from rimmers,they fit very well and are very similar quality to the originals,i have also new outer weather strips from rimmers which i have not fitted yet but they also seem of reasonable quality.Edin Dundee wrote:Where's the best place to buy them (assuming they are still available)?
Re: Window Seals
Thanks guys, I'll try Rimmers for the quarterlight seals - and then see where the rest of the windnoise comes from!
Thanks for Witor tip, I've already bookmarked his site and noticed the channel thingy, good to hear it verified.
