Wolfrace wheels
Posted: Tue Dec 15, 2009 2:07 pm
by merlind100
More of a general inquiry than a serious search at the moment, hence posted here and not in the wanted section. I fancy a set of these for the car in 13 or 14 inch, does anybody have any?
Re: Wolfrace wheels
Posted: Tue Dec 15, 2009 4:09 pm
by Howard81
There was a 14" set on eBay recently... I was tempted but not sure if 14" would fit on a Dolly!
Re: Wolfrace wheels
Posted: Tue Dec 15, 2009 4:35 pm
by Oli_88
Iirc, 14" wheels do fit with a bit of work...
I think it was Lewis that posted about them before.
Re: Wolfrace wheels
Posted: Tue Dec 15, 2009 5:56 pm
by Andybrad
My dolly has 14" wheels shod in 185/60 tires with no rubbing, arches arn't rolled but car is at standard height.
Re: Wolfrace wheels
Posted: Tue Dec 15, 2009 8:01 pm
by merlind100
Mine is lowered quite a bit so I suspect that I'll have to go for 5.5x13", It's getting them with a 3.75 pcd that seems to be the problem.
Re: Wolfrace wheels
Posted: Tue Dec 15, 2009 8:38 pm
by Andybrad
Depends on what profile tires you use, I'm lowering my car in the next couple of weeks so I'll just put lower profile tires on if need be. I think some guys have 15's on their dolomites.
Re: Wolfrace wheels
Posted: Tue Dec 15, 2009 9:03 pm
by Mondeo Owner
Spooky.
I decided that a set of "winter wheels" might be worthwhile for mine and spent last night browsing ebay for Minilites then Wolfraces (without success)
What PCD/Offset do I need to look for? (or any other technical stuff?).
I'm in no rush so suggest if you find a set flag it or PM me as I don't want to bid up a set against a fellow forum member.
EDIT - Mine isn't lowered so 14" might be OK for me.
Re: Wolfrace wheels
Posted: Tue Dec 15, 2009 10:03 pm
by merlind100
it occurs that Triumph front ends were popular with hot rodders for a while as were wolfies so it might be possibale to pick up a couple of pairs
Re: Wolfrace wheels
Posted: Wed Dec 16, 2009 12:03 am
by mbellinger
Wolfrace (back in the day) did a number of applications for the TR7. My own TR7 wore Woolfies for a while.
Those are the boys you need to find.
Re: Wolfrace wheels
Posted: Wed Dec 16, 2009 1:33 am
by Mondeo Owner
Re: Wolfrace wheels
Posted: Wed Dec 16, 2009 4:31 am
by Oli_88
Iirc Stag wheels don't fit, well not without a lot of hassle.
So surely by association wheels for a stag would be much the same. (thinking out loud)
Re: Wolfrace wheels
Posted: Wed Dec 16, 2009 10:43 am
by merlind100
4.5" pcd on Stag wheels, if I was to go to the trouble of changing that I think I'd go for Fords 4.25" pcd. Many more options then for wheels and brake upgrades
Re: Wolfrace wheels
Posted: Thu Dec 17, 2009 10:42 am
by DOLLY76
OH now I get it! In Australia "Wolfies" are called "Jelly Beans" because the holes in the radius are shaped like jelly beans. Hmmm Now I want a set
