Out of Hibernation
Posted: Sun Feb 07, 2010 8:52 pm
As the Magenta Sprint is at the spray shop, I took the opportunity to give my track Sprint a shake-down. After charging the battery it started first time. Not bad seeing as it hasn't been touched since October and has remained outside on the drive.
I jacked up the rear & checked the rear brakes and also topped up the back axle. Then I checked the front brakes & cleaned the discs up as they were a bit rusty.
First thing this morning I whipped the rocker cover off & re-torqued the head. Then give it some fresh oil & filter. I checked the other fluids as well.
Finally I checked all the lights & gave the wheels & engine bay a bit of a clean (and the exhaust tail pipe).
Hoping to get it MoTed next week some time.
