Page 1 of 19
Redtop sprint
Posted: Sun Aug 15, 2010 2:31 pm
by iandollysprint
Just started my redtop conversion on my sprint.
Plan is as follows
Redtop engine fully rebuilt with pocketed pistons, 276 cams, R1 carbs, bogg brothers manifold, megajolt ignition, bespoke engine mounts, bespoke exhasut manifold to 2 inch sprint sports system. Getrag Manta 5 speed box, bespoke prop. Big winged sump. I have most of the bits.
Hoping for 200bhp and for it to be done for early next year.
Hopefully I have added pics correctly showing initial positioning of engine and box. Gearbox bellhousing seems to foul rack at the moment, need to get the engine further down and remove transmission tunnel for better location.
I'll update As I progress.
Ian
Re: Redtop sprint
Posted: Sun Aug 15, 2010 6:12 pm
by topfuel
looking good. i'm still doing project zetec..3yrs and counting!!!
cheers terry
Re: Redtop sprint
Posted: Mon Aug 16, 2010 11:40 am
by Andybrad
Looks good, should comfortably make 200bhp at that spec, I'll be watching with interest as I also have most of the parts required for the conversion. Keep the pictures coming!
Re: Redtop sprint
Posted: Mon Aug 16, 2010 12:10 pm
by eightiesflamer
Engine is too far forward, push it back 6 inches
Darren
Re: Redtop sprint
Posted: Mon Aug 16, 2010 12:51 pm
by JPB
eightiesflamer wrote:Engine is too far forward, push it back 6 inches
Darren
I also thought it looked a long way forward, but then would the gear lever not be too far to the rear if you pushed the whole lot back? That might make it a tight squeeze in the tunnel or require the remote to be taken out and the lever fitted to the gearbox directly. Is that possible on this 'box?
On the other hand; with it where it is, then assuming that you can find a radiator that'll go, the engine isn't that heavy so shouldn't affect the balance of the car too much.
But these are all things that can be fettled before any permanent welds are made and the idea's a great one.
:thumbsup:
Re: Redtop sprint
Posted: Mon Aug 16, 2010 5:14 pm
by jikovron
excellent looking project the engine looks like its been prepped very nicely
if you get the hunger for more than 200bhp you could always pop a vauxhall pattern saab 2.3 turbo motor onto the manta gearbox :mrgreen:
Re: Redtop sprint
Posted: Mon Aug 16, 2010 5:20 pm
by mbellinger
Nice to see it coming together, and another french blue Redtop at that!
On mine cylinder 3 sits roughly between the suspension turrets, indicating as others have alluded, that yours is a bit further forwards at the moment.
Nice to see it coming together.
Re: Redtop sprint
Posted: Mon Aug 16, 2010 7:57 pm
by iandollysprint
Guys
Thanks for all the comments.
Yes engine seems too far forward at the moment and way too high, have pm'd mbellinger for his advice. Eighties flamer - seen pics of yours as well and it is "much" further back than mine. Did you use the manta gearbox or ford type 9? Manta box would appear to foul tunnel opening if I take it back that far, would be great for balance though.
I'll keep the pics coming as I go.
Ian
Re: Redtop sprint
Posted: Mon Aug 16, 2010 8:37 pm
by eightiesflamer
Ian, yes I did use the manta box but after the third power run at emeralds rolling road it leaked a good litre of gearbox oil and has done it a few times since then, I am bored of it now so am trying to shoe horn a TVR box in, the shifter was however in the perfect position, I think I had to elongate the hole a little in the removable tunnel.
Hope this helps
Darren.
Re: Redtop sprint
Posted: Mon Aug 16, 2010 8:58 pm
by iandollysprint
eightiesflamer wrote:Ian, yes I did use the manta box but after the third power run at emeralds rolling road it leaked a good litre of gearbox oil and has done it a few times since then, I am bored of it now so am trying to shoe horn a TVR box in, the shifter was however in the perfect position, I think I had to elongate the hole a little in the removable tunnel.
Hope this helps
Darren.
Sure does. Just deciding where to locate the box/engine. Does your use cable or hydraulic for clutch? TVr box sounds interesting.
Ian
Re: Redtop sprint
Posted: Mon Aug 16, 2010 9:16 pm
by eightiesflamer
Ian
I used a cable for the manta box however I am going hydraulic on the TVR box.
Darren
Re: Redtop sprint
Posted: Sat Aug 21, 2010 4:16 pm
by iandollysprint
Now had a good rummage in the engine bay with the block and gearbox. I have a feeling that the best way to fit it is to get it back as far as possible and as low as possible.
There is no way that the big winged sump will fit though if I take it back so far, but this seems the best option as per eightiesflamer approach. :shock: :lol:
I think I'll be knocking up a bespoke big winged sump with the wing towards the front of the engine. That way I will not have to chop any of the subframe. Exhaust manifold looks like it will be an interesting fit!
Re: Redtop sprint
Posted: Sat Aug 21, 2010 4:26 pm
by iandollysprint
And the gearbox inside the car - seems a very nice fit if a little too high at the moment
Re: Redtop sprint
Posted: Sat Aug 21, 2010 4:58 pm
by JPB
Just a thought; could you dry sump the engine as an alternative to increasing oil capacity by means of the winged sump that won't fit with that more rearward mounting position? 8)
Re: Redtop sprint
Posted: Sat Aug 21, 2010 5:08 pm
by iandollysprint
JPB wrote:Just a thought; could you dry sump the engine as an alternative to increasing oil capacity by means of the winged sump that won't fit with that more rearward mounting position? 8)
Yes, probably. But they aint cheap!!!!!!!!!!!!
I might have a go at chopping an old sump up. It would need to be really shallow right at the front of the engine (just like the big winged sump) so as to avoid the subframe cross member. I don't want to chop the cross member off if I can help it.
Ian
