Pedal Box assy ATT ALG1K
SprintV8
#1 Post by SprintV8 »
Daz.
What was the pedal box you used.
Foward/reverse.
Tried doing a serch on the old site but it appear's to have gone.
Need to order up soon.
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
ALGIK
#2 Post by ALGIK »
It was a reverse kit
The two cyl nearly touch the steering column where the column adjuster is
SprintV8
#3 Post by SprintV8 »
Cheer's Daz
That's what I thought.
Going for the Triple Master set up as i'm using the TVR hydaulic Clutch.
Next Question.
Your using AP master's correct did you manage to find a part number or Master cylinder bore size.
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
ALGIK
#4 Post by ALGIK »
sorry only just seen this
Yes the masters are .750 for front and .700 for rear
short APs
Cannot remember the cp No :oops:
