Old Core
Posted: Mon May 07, 2007 12:24 pm
by MalcGE
Folks, there has been quite a bit of interest in the adjustable tie bars in the last issue of DM. We need some old units 'as core' to get the whole exchange programme to fly. Like many of these initiatives, small batches are the way to go. The amount of old units that are needed on any exchange item are quite large as innevitably you end up with about four categories
Produced Units Ready to Go
Old Units with member awaiting return
Old units at TDC spares accumulating
Old units at manufacturer in production
Say half a dozen at each stage and you have 20 car sets of tie bars needed, 18 more than TDC spares has at the moment
OHV Clutch Slaves also needed
Posted: Mon May 07, 2007 6:58 pm
by David6214
clutch slaves I can probably help you out with a couple, not sure when I can get them to you though. Mr Saitrix should have one as well....I'm having a sort out soon (started with the engines and boxes and working my way down and there will be some stuff coming out from that.
I'll check the list onb the sticky again and see what it is I should be saving Malc.
I reckon I have a 127 alternator, 3 clutch slaves, maybe more another alternator, maybe a rack or two, want any starter motors?
Posted: Mon May 07, 2007 11:20 pm
by MalcGE
David, all of those items are good useful core, thanks
Posted: Tue May 08, 2007 8:40 am
by Sprint36
Malc, loads of tie bars in my garage with the bush section worn. I'll have to work out a way of getting them to you.
David
clutch slaves
Posted: Wed May 09, 2007 11:42 am
by BDN712V
I do have 2 clutch slaves kicking around at the moment (somewhere) that need attention to the bores - not entirely sure when I'll see them again amongst the other bits I've got, but I will remember to send them on eventually!
Tim
Posted: Wed May 09, 2007 8:15 pm
by MalcGE
Thanks chaps. Dave if you do fancy a trip down to Leamington to see some action, i'm there every other Sat Morning with my lad Matt
http://www.mrkarting.co.uk/
Posted: Thu May 10, 2007 8:44 am
by Sprint36
Malc, I'll bear that in mind, but my lads are normally swimming on saturday mornings, so it might not be until July!
David
